Offset Question
Old May 1, 2002 | 09:54 AM
AllMotorITR's Avatar
New User
Default Offset Question
On King Motorsports' web site, it says that the Mugen MF-10s come in +43 and +50 offset, which is better for the ITR? What difference does it make?
Old May 1, 2002 | 09:58 AM
Big Phat R's Avatar
Default Re: Offset Question (1 FAST R)
50mm offset is the same as stock offset. You can use up to a 225/45 tire with this rim type.
43mm offset pushes the rim "out" by 7 mm relative to the 50mm and makes the tires stick out more - but you can only run a 215 width tire.
I'm not sure if there is a huge track width difference between the two.
You can also think of it like this: A 43 mm offset rim is like a 50mm offset rim with a 7mm hub spacer.
Mugen rims
Old May 1, 2002 | 10:12 AM
Austin's Avatar
Default Re: Offset Question (Phat Bastard)
Don't mind this incorrect post...please read my other reply
Stock 15X6
+50mm
Mugen MF-10's 16X7
+43mm
+50mm
The +43mm offset pushes the tires farther out of the wheel well, the outside lip of the rim will be 1.25" farther out of the wheel well than the stock rims, gives you a +14mm(total) larger trac, and (correct me if I'm wrong)also places more weight on the inside of the tires, gives you a slight increase in negative camber...more for track use, I own a pair of these.
+50mm offset keeps the rim relatively inside the wheel wells, but from the stock rim the rim will stick out of the wheel well 1" farther. More for street driven applications.
Hey...if I'm wrong, someone correct me, but this is the information that I have accumulated over the last year and believe to be correct.
Austin
[Modified by Austin, 11:51 AM 5/1/2002]
Old May 1, 2002 | 10:23 AM
reefer_bob's Avatar
Default Re: Offset Question (Austin)
Are you sure on the 1.25" further extension?
I would think that it would be the 7mm (.2756") + .5" (1/2 the extra tire width) for a total of .7756" further out per side...
Old May 1, 2002 | 10:50 AM
Austin's Avatar
Default Re: Offset Question (reefer_bob)
...now I understand more about offset: http://www.tirerack.com/wheels/tech/offset.htm
Looks like I had a few things off...
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
[Modified by Austin, 11:52 AM 5/1/2002]
Old May 1, 2002 | 11:17 AM
Unlimited's Avatar
New User
whats the offset of the jdm itr 16" rims?
Old May 1, 2002 | 12:23 PM
slash00R's Avatar
New User
Default Re: Offset Question (Unlimited)
I don't see how the smaller offset pushes the rim out. I would think if there was a larger offest it would mean the middle of the rim was closer to the middle of the car .. someone edumucate me
Old May 1, 2002 | 12:30 PM
JPP's Avatar
JPP
Default Re: Offset Question (slash00R)
Look at the drawing a few post up. The higher the offset the more you can push the wheel inside the well and the smaller the offset the less you can push it in.
Old May 1, 2002 | 12:49 PM
New User
Default Re: Offset Question (JPP)
So for a street setup +50 would be ideal? I don't want the wheel to be wide enough that it sticks out? Will I be happy with a +50 MF-10 if I decide to go to the track?
Old May 1, 2002 | 01:03 PM
Black R's Avatar
25 Year Member
...why if you're selling the car?
Old May 1, 2002 | 01:18 PM
Cosworth's Avatar
50+ offset will be more than enough.
Old Jun 9, 2002 | 02:09 PM
SoCal ITR's Avatar
Default Re: Offset Question (Cosworth)
Would 215/45 on a 16x7.5 tire rub?
Old Jun 9, 2002 | 02:11 PM
Reid's Avatar
Global Moderator
Default Re: Offset Question (SoCal ITR)
What offset?
Old Jun 9, 2002 | 03:05 PM
Saga's Avatar
The extra 7mm would help on the track. Same idea as one would use wider tires in that matter.
But usually the concern is more towards the clearance issue...ie. if you are planning to use a larger brake caliper, then the +43 offset MIGHT clear the caliper without the use of spacers.
Old Jun 9, 2002 | 03:40 PM
Floyd's Avatar
You have to consider the measurement is relative to the mounting face of the hub.
Old Jun 9, 2002 | 04:12 PM
SoCal ITR's Avatar
Default Re: Offset Question (Reid)
Not sure, Kosei K1 16" is the wheel.... I'll see if I can find it.
Old Jun 9, 2002 | 05:19 PM
Saga's Avatar
Default Re: Offset Question (TypeR1244)
It also depends on the width of the rim.
Old Jun 9, 2002 | 05:38 PM
SuperTwinz's Avatar
with +50mm offset you can always use spacers
[Modified by SuperTwinz, 7:38 PM 6/9/2002]
Old Jun 9, 2002 | 05:54 PM
IntegraR0064's Avatar
Here, I know it's another board...but I did a huge post on offset...explanation's there, pros and cons of different offsets, etc, etc
http://www.hondavision.com/showthrea...&threadid=5638
Hope that helps.
[Modified by IntegraR0064, 9:54 PM 6/9/2002]
Old Jun 9, 2002 | 05:55 PM
i got question..
if i get 5x114.3 +40mm(15")
what will happen?
would it be more sticking out or going in to the well than stock rims?
Sticking out. And +40 should work fine.
jhamlett5
Jan 28, 2012 03:30 AM
aln2590
Aug 23, 2007 11:05 PM
JusT a Cx
Honda S2000
25
Jun 12, 2005 11:26 PM
Takeoff
Jun 4, 2002 06:49 AM
mickey513
Mar 30, 2002 06:03 AM
