O2 sensor
Old Dec 21, 2001 | 10:00 AM
JSpecwest's Avatar
New User
Default O2 sensor
What brand does Honda use for their 02 sensors? Are the primary and secondary sensors the same? Will a different brand like Bosch be similar? Also if anyone knows what wire from the sensor goes into which pin position it would be appreciated.
Old Dec 21, 2001 | 10:10 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: O2 sensor (JSpecwest)
The Primary and secondary are different part numbers.. but I think that's just because the secondary has the "gasket" or whatever it's called for the floorpan. A bosch will work fine if you figure out the numbers.. I have to check but on the OEM o2s green is heater power, white is signal, and the black across from each one is that wires grounds (across from green, is heater ground, etc).
Oh yeah, you will have to figure out the bosch wires
[Modified by Dave-ROR, 2:12 PM 12/21/2001]
Old Dec 21, 2001 | 10:13 AM
sackdz's Avatar
Default Re: O2 sensor (Dave-ROR)
Also, their operating voltage is 0V-1V
JSpecwest's Avatar
New User
Thanks Dave
Old Dec 21, 2001 | 10:16 AM
JSpecwest's Avatar
New User
Just called the dealership. $245 for one fuggin sensor!! Ummm...guess Ill just have to live with my CEL for now. Anyone know some cheaper sensors?
b00st-0wnz's Avatar
Default Re: O2 sensor (sackdz)
err sackdz finished my horribly written post for me. thanks
Old Dec 21, 2001 | 10:19 AM
Jason's Avatar
check w/ Mike K, I'm sure he can do better, albeit will still be a ripoff from the dealer regardless
Old Dec 21, 2001 | 10:24 AM
b00st-0wnz's Avatar
Default Re: O2 sensor (typer98)
yep, mike k is def cheaper than that.. I got my new primary o2 from him.
Old Dec 21, 2001 | 11:08 AM
norice's Avatar
I have read somewhere that if you clean the sensor with brake cleaning fluid it can start working properly again.
BTW, I am going to be removing my header this weekend and have heard that it can sometimes be very difficult to remove the oxygen sensor for the header. Any tips on this? Should I buy a specific tool for this?
Old Dec 21, 2001 | 11:28 AM
R134's Avatar
Default Re: O2 sensor (norice)
The factory one is made by Denso. Mine threw a cel until I cleaned it with brake cleaner.
jorge59la
Feb 15, 2010 08:16 PM
xXxGallo24xXx
Aug 23, 2008 12:27 PM
RedEj8
16
Feb 11, 2007 07:35 PM
conguero
Nov 18, 2004 06:36 PM
HXMan
Apr 26, 2002 08:13 AM
