Is this Normal?
Old Aug 7, 2004 | 03:08 PM
BrokenLimits's Avatar
Default Is this Normal?
So I just built my LS VTEC with JE Pistons Eagle Rods 12.5:1 compression all new bearings balanced etc etc etc
I changed the oil today actually for the second time (1st time was startup) and the car had 2,000 miles on it.
The magnetic Drain plug contained this:
I am thinking it normal but I figured I would run it by you all.
REMEMBER it only has 2,000 miles on it...
Old Aug 7, 2004 | 03:10 PM
Outkast_CL9's Avatar
Default Re: Is this Normal? (BrokenLimits)
doesn't look good...but I couldn't tell you if it is normal or not.
Old Aug 7, 2004 | 03:19 PM
Chris93Si's Avatar
I would guess that's totally normal on a freshly built motor.
Old Aug 7, 2004 | 03:23 PM
Default Re: Is this Normal? (Chris93Si)
no one has a definitive huh?
Im kinda sweatin over here LoL
Old Aug 7, 2004 | 03:32 PM
Bbasso's Avatar
there is always going to be some but as to how much is up to the builders.
A 100% perfectly clean job does not always happen, So expect some and keep checking.
I would cut open the oil filter and see whats inside there.
Old Aug 7, 2004 | 03:33 PM
Default Re: Is this Normal? (Bbasso)
I may take these pics up to the block builder and ask him...this has got me pretty nervous
I may drop the oil here in 500 miles again
Old Aug 7, 2004 | 04:17 PM
I spoke to a few people and everyone says its fine its just the rings shaving to make perfect fits and I have nothing to worry about. I guess we will see when I drop it again here in 500 miles or so thanks to my paranoid ***...
Old Aug 7, 2004 | 04:22 PM
uNF$@#!'s Avatar
if your not experiencing any "oddness" or any signs of motor issues, i would suspect when they sleeved/honed the block they probably did not clean everything out.
is this good? well....its not the best scenario, but with hired help, you always have to expect the worst.
i wouldnt want all that metal floating around in the motor.
i would start changing the oil every 500-1000 miles or so for another 5000 miles, unless you plan on bringing the motor back to the guys to have a lookie.
Old Aug 7, 2004 | 04:40 PM
onePOINTsix's Avatar
Default Re: Is this Normal? (w@@t w@@t)
on new motors i always tell people to drive it for 20miles (break-in) and change the oil, then change it every 500miles for like 2500miles. works great for me i bet if you whould have changed your oil a little more often the shavings wouldn't have been there in 2000miles
Old Aug 7, 2004 | 05:36 PM
mugenracer's Avatar
for a newly built engine i'd say thats near enough normal, when i had my last integra B18C rebuilt i got the same crap on the drain plug after 500miles, i then changed the oil again after another 1000miles and had a few metal shavings and i then changed it again after another 1000miles and it was clean, so i figured everything had been caught at that stage, i checked it after every oil change after that and it was fine with maybe 4 or 5 metal shavings on it but nothing to worry about.
Old Aug 7, 2004 | 05:39 PM
Nishant's Avatar
Default Re: (mugenracer)
continue changing it at every 500miles if you can. the metal shavings should go away. once they do, go back to regular oil change intervals
Old Aug 7, 2004 | 07:19 PM
Ill's Avatar
Ill
Default Re: Is this Normal? (Sideout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">on new motors i always tell people to drive it for 20miles (break-in) and change the oil, then change it every 500miles for like 2500miles. works great for me i bet if you whould have changed your oil a little more often the shavings wouldn't have been there in 2000miles</TD></TR></TABLE>
Good suggestions. You need to stop driving it and change the oil immediately, not in 500 more miles. You are overdue. New motor should be startup / 20, then 500 miles MAX on the 'second' oil change. Then 500 - 1000 more MAX on the third, especially rebuilt. New filter each time too. Oil is cheap insurance for all the work and money of a new mo. Continue monitoring the plug. If you get shavings, keep up the frequent (500 - 1K) change intervals for as long as 5K total. Some shavings are normal. At least you had the magnetic plug - good thinking!
Old Aug 7, 2004 | 07:32 PM
Sinbro2's Avatar
Default Re: Is this Normal? (Ill)
magnetic plug=your friend
Old Aug 7, 2004 | 11:37 PM
Default Re: Is this Normal? (sinbro2)
thanks guys, you made me feel a lot better about this. I will definitely change it again at 500 miles and then again at 500 until they go away.
I appreciate all the help
Old Aug 7, 2004 | 11:42 PM
Opie's Avatar
Well, treat it as you would a new car. Swap your original oil @ 1k 3k and again @ 5k, then start up a normal lube pattern
&lt;Who tried getting a lil' lubin' tonite but ended up getting smacked at the bar
Old Aug 8, 2004 | 12:06 AM
Default Re: (opie)
LoL I met you, I introduced myself to you at the ITR expo in the Hotel parking lot when you were on your way back home.
Old Aug 8, 2004 | 12:21 AM
DsITR's Avatar
Default Re: (BrokenLimits)
I would just be glad it's on the drain plug
You could send in your oil to have it analyzed.. but everyone seems to think it's pretty normal for a fresh block.
civiccoupe94
Apr 18, 2006 12:07 AM
jdkornlp
Sep 26, 2005 05:56 AM
Honda only
Honda S2000
22
Sep 5, 2004 06:34 PM
FabulousSi
Apr 1, 2003 04:31 PM
jeddy0120
Feb 6, 2003 06:36 AM
