NEED HELP!! LUG PROBLEM
Old Jul 12, 2001 | 07:58 PM
SoulDigger's Avatar
Default NEED HELP!! LUG PROBLEM
What is the best way to break loose stubborn lug nuts. I feel like something is going to break with anymore pressure. Also what is the correct torque specs for ITR wheels. Thanks
Old Jul 12, 2001 | 08:02 PM
Mike M's Avatar
Founding Member
Default Re: NEED HELP!! LUG PROBLEM (Wraith)
Air Ratchet
Torque Specs 80lbs/ft and tighten in a crisscross design
Old Jul 12, 2001 | 08:03 PM
Toda Party's Avatar
Default Re: NEED HELP!! LUG PROBLEM (TypeRmsm)
Yup, 80lbs
Old Jul 12, 2001 | 08:05 PM
SoulDigger's Avatar
I only tighened them to 70lbs and a couple of the damn things won't move! Unfortunatly I am living in the cave man era and only have hand tools. Would some penatrating oil help?
Old Jul 12, 2001 | 08:06 PM
Jason's Avatar
80 ft lbs...
Old Jul 12, 2001 | 08:08 PM
R0476's Avatar
Step on that **** or use a breaker bar.
Old Jul 12, 2001 | 08:10 PM
Cosworth's Avatar
Default Re: NEED HELP!! LUG PROBLEM (typer98)
What chu fools talking about it's 109 Nm/ft. ! (same as 80 lbs/ft)
Old Jul 12, 2001 | 08:20 PM
SoulDigger's Avatar
Default Re: NEED HELP!! LUG PROBLEM (R0476)
Step on it? Man it already sounds like I'm going to break a stud or strip a lug. How much can it take - 165lbs of human power?
Old Jul 12, 2001 | 08:26 PM
Smurf's Avatar
New User
Perhaps when they were tightened before, the problemsome lug was crossthreaded and hence the difficulty of removing it....
Old Jul 12, 2001 | 08:39 PM
SoulDigger's Avatar
Default Re: NEED HELP!! LUG PROBLEM (Smurf)
Thanks for the quick responses guys. Seems like the penatrating oil is doing the trick ever so slowly. Just broke loose a few more, only about 4 or five left.
Old Jul 12, 2001 | 08:40 PM
rudeS2k's Avatar
use some 2w40, let it sink in and hope for the best,dude..
Old Jul 12, 2001 | 09:10 PM
GRM Scott's Avatar
25 Year Member
yeah, invest in a torque wrench and never let ANYONE tighten your wheels with an impact gun...torque bars my ***
Old Jul 13, 2001 | 09:29 AM
ralph_wiggum's Avatar
New User
Default Re: NEED HELP!! LUG PROBLEM (Aleph)
MAKE SURE YOU TURN IT THE RIGHT WAY!!!!
just a thought
Old Jul 13, 2001 | 09:51 AM
SoulDigger's Avatar
Default Re: NEED HELP!! LUG PROBLEM (darudeboi)
Thanks for all the help. Finally got the last one to break loose this morning. I am worried about this happening again. I am using the black Rays lightweight lugs and TE-37's. Should I grease the stud and lug before I put them back on? Any idea's?
Old Jul 13, 2001 | 09:58 AM
EPGONZALEZ's Avatar
yeah put some anti sieze on the threads before you put them back on..will prevent corrosion as well as getting a more even torque
Old Jul 13, 2001 | 10:35 AM
Warren's Avatar
Wrong-Way Wang
Default Re: NEED HELP!! LUG PROBLEM (EPGONZALEZ)
If you put on any sort of penetrating oil, make damn sure you clean it off!!! Use brake cleaner. I don't like to use anything on the studs. Some people put a LITTLE anti-seize on. Make sure none of it comes into contact with the part of the lugnut that actually touches the wheel.
Warren
Old Jul 13, 2001 | 12:12 PM
SoulDigger's Avatar
Default Re: NEED HELP!! LUG PROBLEM (Warren)
cool thanks again guys
JoanC
Oct 19, 2017 10:37 PM
texrex2002
Mar 30, 2008 01:03 PM
BoostedGSRBubble
Oct 30, 2002 09:04 PM
94civicx
Aug 19, 2002 05:24 PM
