Need help with eld sensor(pic)
Old May 10, 2006 | 10:39 AM
capzuk's Avatar
Default Need help with eld sensor(pic)
Hello,right my car ticks over at about 1500rpm and then drops after a few seconds to 1200rpm,diagnostic puts a fault up saying ELD and basicly somone has removed mine and i can't find any wiring for the sensor to be pluged into under the fuse box,why would this be done?
^^^This is what im left with^^^
Also on my list of problems ,there should be a pipe going from the tube above the sensor but there isn't,What's it for?
Sorry pics may be a bit large
Old May 10, 2006 | 05:05 PM
cjames235's Avatar
Default Re: Need help with eld sensor(pic) (capzuk)
wow those pics are huge!! as far as the eld goes there is no wires that come out of the box for it........ its got 2 tabs on it and it snaps into that square and then the end screws for the 2 fuses next to it is what the eld goes to
the nipple on the throttle body is for emissions i believe......... cant remember what it was for as the USDM cars dont have that one
sorry if that first bit is confusing
Old May 11, 2006 | 01:49 AM
capzuk's Avatar
Default Re: Need help with eld sensor(pic) (neo_)
So are you saying i have a jdm throttle body?
And i dont know what to do about this ELD there's no point getting one if i have nothing to plug it into
Yes it is rhd(uk)
Modified by capzuk at 3:33 AM 5/11/2006
Old May 11, 2006 | 10:40 AM
capzuk's Avatar
Anybody know why the eld would be removed??????????
And what does that pipe on th t/b do??
Old May 11, 2006 | 10:46 AM
capzuk's Avatar
Ok , so whats the difference between the two?
Old May 11, 2006 | 05:25 PM
cjames235's Avatar
i already told you about the eld........ there is no plug for it....... it only screws into the 2 fuse end screws and snaps into that boxed area that is empty on your car
Old May 8, 2008 | 07:45 AM
sdots's Avatar
New User
facing the same problem with the ELD CEL.
The nipple is connected via a vacuum hose, connecting from the nipple in your picture to the carbon canister located on your firewall.
hope this helps
Old May 8, 2008 | 08:02 AM
crx(gator)'s Avatar
Default Re: Need help with eld sensor(pic) (sdots)
the ELD has nothing to do with vacuum...
ELD = electronic load detector
there is nothing electronic going on with the vacuum line...usually ELD is for the alternator and it's output voltage...
Old May 8, 2008 | 08:11 AM
R.Kelley's Avatar
that nipple on the Tbody i believe goes to the canister
Old May 8, 2008 | 02:30 PM
ithrowpoop's Avatar
Default Re: (R.Kelley)
if you have a bad eld, you need a new fuse box. it is a part of it and it plug in on the under side of the fuse box.
frog169
Aug 4, 2006 12:18 PM
-JSpecEk*9-
May 2, 2006 11:28 AM
dohcMONSTER
15
Jul 5, 2004 06:26 PM
Turbo Powa
14
Mar 19, 2003 07:20 PM
