Need help on CEL??
Old Jan 15, 2007 | 07:31 PM
400WHPITR's Avatar
Default Need help on CEL??
When I try to read the CEL flashing codes to find the DTC on my ITR, the CEL keep flashing. I only see long flashes, no short flashes. Can anyone help me out?? Thanks a lot
Old Jan 16, 2007 | 06:32 AM
andyt's Avatar
Default Re: Need help on CEL?? (400WHPITR)
You just need to pay closer attention.
First of all, are you SURE you have the connector by the computer jumpered together?
I find that using a little crimp connector works perfectly.
Second, the flashes will ultimately repeat. If you are throwing multiple codes they will go in succession, and then repeat. If its truly only long flashes, you need to figure out where the break is, and obviously, count the number of flashes.
Then we might be able to help you.
Unless you would like to take a video of it, post it, and have someone else count for you...
B20IntegGSR
Nov 29, 2007 07:21 PM
Exxel82
May 1, 2007 08:15 AM
jrs
Sep 13, 2005 09:44 AM
Phatch99
Feb 17, 2005 07:56 AM
