miss shift
Old Jun 26, 2005 | 01:33 PM
clayton bigsby's Avatar
Default miss shift
this guy bought this type R and with in an hour of purchesing the car disastret struck he said he missed a 3rd to 4th shift and hit 2nd indsted at about 9800
as you can see it was bad
this valve would not come out what so ever and the stem is stuck like chuck
and the JG valve spring broke in to 3 pices
Old Jun 26, 2005 | 01:35 PM
ZygSpeed's Avatar
Default Re: miss shift (clayton bigsby)
So, you're posting someone else's bad luck?
Ask him how much he wants for the car ... now (I need a chassis for the turbo motor).
Old Jun 26, 2005 | 01:48 PM
b19coupe's Avatar
Wow, sucks to be him
Old Jun 26, 2005 | 03:26 PM
well he has a 2001 gsr swap now with ctr cams total downgrade.
Old Jun 26, 2005 | 03:38 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: miss shift (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">So, you're posting someone else's bad luck?</TD></TR></TABLE>
Luck had nothing to do with it.
As I've said before...
It takes at least TWO different errors to accomplish a money shift:
1) Putting the shift lever in the wrong gear
2) Failing to do anything about it (i.e. putting the clutch pedal back in) in time, when seeing the revs start shooting up past redline.
So that's like asshat squared.
Old Jun 26, 2005 | 03:51 PM
he even cracked the sleave on a C5 block
RTW DC2R's Avatar
that sucks. sometimes you gotta learn the hard way next time I bet he will push the clutch in a lot sooner and faster.
Old Jun 26, 2005 | 03:55 PM
Mythias's Avatar
Default Re: miss shift (nsxtasy)
I must admit, I agree with nsxtasy. It's driver error compounded by further driver error.
Old Jun 26, 2005 | 06:16 PM
Azcheron's Avatar
Default Re: miss shift (mythias)
pure stupidity
Old Jun 26, 2005 | 06:52 PM
d.n.d.'s Avatar
Default Re: miss shift (Azcheron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">pure stupidity</TD></TR></TABLE>
i have to agree....within an HOUR?? id cry if i did that to my R!! he mustve been eager to drive it.....but still no excuse so sad to see an engine like that
Lucky-R's Avatar
it might have been more wise to have atleast gotten comfortable with the car and grasp a better feel of "driving" it before the flogging.
Old Jun 26, 2005 | 06:56 PM
machgo5go's Avatar
damm kids !
Old Jun 26, 2005 | 08:06 PM
Ron M's Avatar
what a waste of a nice c5 engine. idiots shouldnt buy nice things
Modified by RonnieDC2 at 11:19 PM 6/26/2005
Old Jun 26, 2005 | 08:31 PM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Luck had nothing to do with it.
So that's like asshat squared. </TD></TR></TABLE>
I can't wait till you do it.
&lt;-------------------Seen excellent drivers with years of track experience money shift, and done it himself.
Old Jun 26, 2005 | 08:57 PM
Haleiwa-Brando's Avatar
Now I don't feel so bad after killing my engine after four days. 1 hour is a pretty good record.
Old Jun 27, 2005 | 09:00 AM
jdmjunky27's Avatar
Default Re: miss shift (Haleiwa-Brando)
sigh...
Old Jun 27, 2005 | 09:23 AM
acuracy r's Avatar
Default Re: miss shift (jdmjunky27)
this just happened to me yesterday, luckily everything seems to be ok. i used to say the same thing that most of you are saying, but you know, it only takes 1 little mistake. **** happens, no one is perfect, and im sure you guys would change your tune if and when it happens to you.
Old Jun 27, 2005 | 09:53 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: miss shift (acuracy r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuracy r &raquo;</TD></TR><TR><TD CLASS="quote">it only takes 1 little mistake.</TD></TR></TABLE>
Wrong. As I pointed out above, it actually takes TWO mistakes, not one. And they're not "little" when you consider the consequences.
Any time you let out the clutch pedal, if anything doesn't happen the way you expect it to, your first reaction should be to push it back in immediately. Do that, and you won't do the money shift. If you can't be ready to do that, and if you can't put the shift lever in the proper gear, then you shouldn't be driving a manual transmission car.
Old Jun 27, 2005 | 12:52 PM
onePOINTsix's Avatar
bahh that dosent look too bad... Cone Andrew's looked alot worse cracked #1 sleeve in like 10 places and had a valve loged in a rod
Old Jun 27, 2005 | 03:23 PM
VTEXTC's Avatar
I sortof find it hard to "mishift" from 3rd to 2nd.. i mean what happens when u let go of the gear lever when your shifting from 1st to 2nd? It springs to the middle..
So when going from 3rd to 4th, the only pressure on the stick should be downwards.. not side to side.. lol.
The worst thats wver happend to me was a mishift from 1st to 4th.. being lazy i reckon. (hey even GANSAN did that in the S2K ) It made a popping sound and a small section of my clutch managed to break off and jam No excessive damage fortunately, apart frome a new clutch.
Old Jun 27, 2005 | 08:15 PM
Ford Prefect's Avatar
Default Re: (VTEXTC)
I've been driving my CL-S too much lately, the other day I tried to shift from 5th to 6th in my R
Old Jun 27, 2005 | 08:19 PM
Mythias's Avatar
Default Re: (Ford Prefect)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ford Prefect &raquo;</TD></TR><TR><TD CLASS="quote">I've been driving my CL-S too much lately, the other day I tried to shift from 5th to 6th in my R </TD></TR></TABLE>
f00l.
btw, look forward to meeting ya. I will be in the R and tuned then.
Old Jun 27, 2005 | 09:02 PM
Default Re: (RonnieDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonnieDC2 &raquo;</TD></TR><TR><TD CLASS="quote">what a waste of a nice c5 engine. idiots shouldnt buy nice things
Modified by RonnieDC2 at 11:19 PM 6/26/2005</TD></TR></TABLE>
i totaly agree. considering the fact that R was his first honda didnt help he traded this TT and cash for it
Old Jun 27, 2005 | 09:24 PM
veilsides2000's Avatar
this is like the 20th misshift i have heard about these two weeks alone.
Old Jun 27, 2005 | 11:32 PM
typeR#0427's Avatar
Default Re: miss shift (Lucky-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lucky-R &raquo;</TD></TR><TR><TD CLASS="quote">it might have been more wise to have atleast gotten comfortable with the car and grasp a better feel of "driving" it before the flogging.</TD></TR></TABLE>
My thoughts exactly
nsxtacy, well stated
