LockNut & Key problem...
Old Jul 4, 2004 | 02:38 PM
Girl's Avatar
Default LockNut & Key problem...
Alright, here's my story. About a month ago I raised up my car cuz I have crappy GC Coilovers... Anyways, while putting my wheel back on, I somehow busted off part (1/4) of my locknut. So I was just like... "Ok... Seems to hold", so I just left it as it is.
Today... I was gonna fix up the coilovers to make my car even, cuz I was gonna bring my car in for an alignment... Since for some reason the front right side was lower, I was gonna raise up that side. That was the same wheel that had the broken locknut on it. I put the key on the broken locknut, turn it... BAM! Another part of the locknut breaks off and all the thingies inside my key just shatter...
So now I have half a locknut on my wheel and no key... What should I do? I know I can get a new key from the Dealer for a few bucks, but what about the broken Locknut?
Thanks.
- Girl.
Old Jul 4, 2004 | 03:02 PM
liquidscor00's Avatar
Default Re: LockNut & Key problem... (Girl)
Try to use some WD-40, and a pair of pliers. Or take it to a shop and use a impact gun.
Good luck
Old Jul 4, 2004 | 03:16 PM
Girl's Avatar
I was just thinking... Since I got a broken Nut and Key anyways... Can't I jsut take to Acura, tell them to take off all 4 locknuts. Then just drive home with 4/5 Nuts on each wheel? I'll probably just get some Kyokugen Lugnuts for like 40-50 bucks... Seeing as how that's how much a 4 Locks&Key are at Acura...
Old Jul 4, 2004 | 03:17 PM
BlueR's Avatar
Default Re: (Girl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Girl &raquo;</TD></TR><TR><TD CLASS="quote">I was just thinking... Since I got a broken Nut and Key anyways... Can't I jsut take to Acura, tell them to take off all 4 locknuts. Then just drive home with 4/5 Nuts on each wheel? I'll probably just get some Kyokugen Lugnuts for like 40-50 bucks... Seeing as how that's how much a 4 Locks&Key are at Acura...</TD></TR></TABLE>
kyokugens are made for aftermarket wheels...
you should not use them with your stock wheels
Old Jul 4, 2004 | 03:43 PM
Default Re: (Girl)
Taking it to Acura, wouldn't be a bad idea. Since it is a stock part, let them handle it. They're probably familiar with such an accident. If anything were to go wrong then they can fix it right away.
Old Jul 4, 2004 | 03:49 PM
Girl's Avatar
Default Re: (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
you should not use them with your stock wheels</TD></TR></TABLE>
Hmm... What do you think I should get then? Just the normal Acura LockNuts&Key?
Old Jul 4, 2004 | 03:52 PM
BlueR's Avatar
Default Re: (Girl)
Hmm... What do you think I should get then? Just the normal Acura LockNuts&Key?</TD></TR></TABLE>
if you have stock wheels, you have no other choice
Old Jul 4, 2004 | 04:25 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (BlueR)
The reason you need stock lug nuts with the stock wheels is because of the seating area. The shape of the seating area on the lug nut needs to be the same as the shape of the seating area on the wheels, so that the two mate over the entire area. Stock lugs and wheels have a ball (spherical) shaped seating area, and aftermarket ones usually have a tapered (conical) shaped seating area.
One pic is worth 1000 words:
Old Jul 4, 2004 | 04:29 PM
Girl's Avatar
Cool. Well thanks for the help.
JaySauce
12
Mar 15, 2009 12:48 AM
Han Solo
10
Oct 31, 2006 03:24 PM
Pure_Lude
Jun 27, 2005 07:44 AM
VTECorona
Mar 18, 2003 01:13 PM
