Launch Control Button... where to put it.
Old Apr 15, 2004 | 06:23 PM
WarrenB's Avatar
Default Launch Control Button... where to put it.
Hey guys, my Hondata S200 is getting the final touches of the install tomorrow and I have to decide where I want to put the launch control button.
I currently have a V-AFC mounted where my ashtray once was, but the V-AFC is no longer needed and is being removed. I was thinking of mounting a peice of Carbon Fiber (cut to shape from a buddies broken hood) across where the ashtray was as a custom peice and mount the button there. Any other ideas???
I think the CF peice in the center console would look pretty good too!
Old Apr 15, 2004 | 06:24 PM
WarrenB's Avatar
Default Re: Launch Control Button... where to put it. (WarrenB)
If anyone has any pics of mounted places, post em up too! I'd like to see.
Old Apr 15, 2004 | 07:02 PM
Kendall's Avatar
I would wire it to one of the horn buttons.
Old Apr 15, 2004 | 07:36 PM
CW_97_ITR's Avatar
How about put the ashtray back and get a round switch to fit in the location of the lighter?
Old Apr 15, 2004 | 10:05 PM
nightrider's Avatar
can you explain what the launch control button does for this newb to hondata?
Old Apr 15, 2004 | 10:34 PM
92TypeR's Avatar
FSAE
Default Re: Launch Control Button... where to put it. (nightrider)
Dave, Launch control is basically a secondary revv limit that is controlled by a button, so you press the button and the limiter is moved to a position in ideal launch range (user defined). The program is set to revert back to the normal rev limit at a certain vehicle speed (user defined). Its pretty much to get consistent launches and I guess some people like it, I prefer having direct control over gas pedal modulation...you just floor the gas and it bounces off a lower revv limit until it reaches a certain speed where you start going normal.
This can be done with both Hondata and Uberdata.
Old Apr 16, 2004 | 09:43 AM
nightrider's Avatar
Default Re: Launch Control Button... where to put it. (92TypeR)
i think i'd rather use my foot.
Old Apr 16, 2004 | 10:24 AM
Blumpkin's Avatar
I always use the 8400rpm rev limiter when I launch...wonder why I'm on my 5th set of tires?
Old Apr 16, 2004 | 10:35 AM
Philly_NBP_R's Avatar
Default Re: Launch Control Button... where to put it. (Blumpkin)
launch control = the hOtNess!!!
Old Apr 16, 2004 | 10:41 AM
canuck-mx6's Avatar
Default Re: Launch Control Button... where to put it. (Philly_NBP_R)
how about the knock outs right next to the ebrake?
Old Apr 16, 2004 | 08:00 PM
MAD ITR 55's Avatar
Default Re: Launch Control Button... where to put it. (canuck-mx6)
What about the blank space where the cruise button goes on gsr's and other 94-up integras.
Old Apr 16, 2004 | 09:23 PM
92TypeR's Avatar
FSAE
Default Re: Launch Control Button... where to put it. (MAD ITR 55)
Hondata you can put it almost anywhere you want to.
Uberdata has been known to work really well with using the A/C switch (you must have taken out your A/C of course). But some people have had success with custom buttoms like the Hondata one.
HAMOTORSPORTS
15
Oct 6, 2015 10:30 AM
brandynEG
Engine Management and Tuning
Aug 6, 2012 04:16 AM
speedemon
Feb 15, 2005 05:11 PM
Nextelbuddy
Apr 17, 2004 07:53 AM
