Jun 3 cam
Old Aug 21, 2001 | 09:26 PM
ITR111's Avatar
New User
Default Jun 3 cam
What power will it make when using Jun ECU compare to Toda Spec C with Reprogrammed ECU? if both are using CTR pistons, with 310cc injectors, mugen 4-1 header, test pipe.
any dyno plot??
[Modified by ITR111, 6:26 AM 8/22/2001]
Old Aug 21, 2001 | 10:10 PM
Kengs's Avatar
Default Re: Jun 3 cam (ITR111)
Never mind, I'm an idiot
[Modified by kengs, 7:17 AM 8/22/2001]
Old Aug 22, 2001 | 12:56 AM
Saga's Avatar
Jun = Lots of Power during VTEC
Toda = Power comes in @ around 4000RPM and all the way up
Old Aug 22, 2001 | 12:57 AM
ITR111's Avatar
New User
Default Re: Jun 3 cam (Saga)
so which one will make more peak power?
Old Aug 22, 2001 | 04:04 AM
stretracr's Avatar
Do a search import review did a plot with the c's, jun's, spoon's, stock etc. etc. According to jun there ecu makes @10whp more than with out it. Because of redline is moved and fuel n timing etc.
Old Aug 22, 2001 | 08:23 AM
White Dragon's Avatar
Just out of curiousity, why do you care about peak power?
Old Aug 22, 2001 | 09:08 AM
B18CXr's Avatar
Default Re: Jun 3 cam (White Dragon)
ditto.
Old Aug 22, 2001 | 10:50 AM
FAST94GSR's Avatar
New User
Default Re: Jun 3 cam (B18CXr)
Jun definitely makes more top end power which is advantageous for drag racing. The make peak power at 9-9500 rpms They are definitely the cam to go with. You want to make sure your valve reliefs are deep enough in the pistons. These cams are real big. Its not recommended to advance or retard these cams there so big. You're definitely looking at 220hp easy with the setup you listed. Importreview.com shows a comparison between the toda C's and the 3's.
Don't be misled in thinking you need the 1500 dollar Jun ecu to make the cams work. I'm sure there are people that will sell a copy of that program cheap. I'm sure a Skunk programmed ecu with a VAFC would do the trick. then take it to a dyno with a air fuel meter and dial it in perfect with a 13:1 a/f ratio. ditch that mugen header and get a real header like a sms or hitech. you'll need one of those.
You have to fine tune to get performance just by automatically adding a ecu isn't gonna make the combo work perfect together.
[Modified by FAST94GSR, 2:55 PM 8/22/2001]
Spoonson
20
Dec 8, 2009 07:58 AM
Si_Guy
Oct 14, 2004 12:13 PM
GQ 05YellowEVO8
Jun 1, 2002 06:02 PM
MOTOR R
Nov 27, 2001 12:30 AM
