ITR down pipe
Old Mar 2, 2003 | 02:04 PM
civicsir2's Avatar
Default ITR down pipe
I have a JDM EG6 civic SIR2 that i have recently put a JDM Integra Type r engine in to.
I got a down pipe with the engine that is over 50mm final bore. I need a cat so i can use the flange to make a de-cat pipe so i got the breakers to send me an old cat. however, the one they sent was too small a bore but they said it was off a teg type r. I got them to send me another downpipe so I could compare. This one measured 42mm bore and they insisted it came off the teg.
Basically, what size should the final bore be on a teg type r downpipe. I will obveously use the larger one but still would like to know what is going on.
Also, I ordered a Supersprint stainless header for the teg type r and it had a 48mm bore!! What does the likes of DC sports use???
Sorry for all the q`s but it will be handy to know.
Cheers in advance.
Old Mar 2, 2003 | 03:08 PM
RagingAngel's Avatar
Default Re: ITR down pipe (civicsir2)
Taken from VTEC.net
In order to make exhaust air flow smoother, there are no sharp angles in the header. Furthermore, in order to lighten/strengthen the parts, stainless steel was used.
Impossible to do in mass-production, all exhaust piping is welded together with no sharp edges throughout. Also, the piping was upgraded to 57.2mm throughout to increase air flow.
The muffler is a multi-chamber design, and does a wonderful job of dissipating sound. However, the funnel-shaped piping in-between the chambers makes it a very free-flowing exhaust.
I believe the DC Sports JDM header is 2.5in for the collector. What that is in mm I cannot remember.... HTH
Old Mar 3, 2003 | 11:52 AM
civicsir2's Avatar
Default Re: ITR down pipe (RagingAngel)
Anyone know what bore the type r should have??
slateEKsi
Jul 26, 2010 04:06 PM
young-richie
May 19, 2008 08:02 AM
GetAwayDriver
Oct 12, 2004 09:02 AM
civicsir2
Mar 2, 2003 05:29 PM
