ITR 01-0431 Modification Thread
The car is essentially "done" now, I don't have any big performance or aesthetic changes planned.
If I ever get the bronze CE28s, I'll throw those on.
I have an aftermarket version of the optional '98+ body kit, but I don't really like the fitment, so I'm probably not going to install it and keep looking for someone selling an OEM one, maybe I'll get lucky some day.
I do have some old car stuff to attend to and some fine tuning of the suspension to help correct some of the geometry from lowering it. I also have a backup distributor in case I run into issues latter.
The backup distributor. It seems more likely it could squeak by a CA smog visual check as it’s a "direct replacement" part, unlike getting coil packs, but I wouldn't want to test that at the state ref.
To help correct the suspension geometry, extended ball joints and tie rods that relocate the tie rod end ball joint pivot:
To help with the alignment, a front caster adjusting kit:
Lastly, to help the car drive smoother, a suspension bushing kit, don't need the ones already replaced with the camber kits installed, but this cost less than buying individually:
Seems the pads just needed more break-in time, much more initial bite now, less pedal travel to get decent braking effort.
looks like the image links got messed up, reposting them.
Rays Volk Racing CE28N Wheels 16x7 5x114.3 et 42mm Bronze
There is a load rating associated with the specific bolt pattern... in this case, 5x100 has a maximum load rating of 530kg, whereas, the 5x114.3 patterned wheel has a maximum load rating of 690kg.
^ yeah, the black close-ended lug nuts tie together with the car much better, I noticed how much cleaner it looked afterwards. It was fun to play around with the blue open-ended ones for a little while though.
The car is in storage right now, probably will swap cars again in the spring, then get to work installing the new stuff. I have been debating if I'll install the bushings myself or drop it off somewhere, it's a doable but tedious looking job.
FWIW I believe those wheels will clear the larger Spoon Monoblock with RSX-S 300mm. Not sure about offset though. The monoblocks have smaller pistons (equivalent to a single 54mm piston) vs the twin-block (equivalent to a single 57mm piston) which helps offset the extra front bias from the larger 300mm rotor. When I crunched the number way back when I found it only increased front bias by 1.3%. Stock ITR is 75.7% front bias. And when swapping in S2k front brakes it only changes to 77.0%.
google “zoom engineering rear view mirror dc2”, and you’ll see it sold at various places and all the different styles. One version is even shaped like a race track! Haha.
jhpusa.com is where I got this one, it’s the “TS” model.
NUISANCE
Jun 6, 2014 07:01 AM
99blackcivicSi
Appearance Build Threads
17
Jul 28, 2012 10:08 PM
LSiNtegraDB7
Mid-Atlantic (Sales)
Nov 28, 2011 03:35 PM
