Interior Problem
Old Nov 13, 2002 | 09:09 AM
Chris_R's Avatar
Default Interior Problem
First off, I dont know why the black showed up as that pinkish color in the pic.
Anyways, The fabric at the point where the arrow is pointing is loose on both doors. Anyone else have this problem, and/or know how to fix it? Should I just go to an upolstry shop or somthing? Thanks!
Old Nov 13, 2002 | 09:10 AM
rockwilda's Avatar
Default Re: Interior Problem (OutkastLV)
super glue
Old Nov 13, 2002 | 09:18 AM
b18cu's Avatar
just use some fabric glue or something it's no big deal i've seen it happen on a couple integras
yoshi234's Avatar
I shoot brides
take off the door panel and see if you can attach it (clips or glue?) from the inside.
or j00 can take to dealer if it's still under wty.
Old Nov 13, 2002 | 09:30 AM
skafia's Avatar
25 Year Member
Default Re: Interior Problem (yoshi234)
I doubt any 97's are still under warranty heh.
Old Nov 13, 2002 | 09:36 AM
Hooch'n's Avatar
Default Re: Interior Problem (skafia)
yeah, glue should work.....
Old Nov 13, 2002 | 09:39 AM
Smitdog's Avatar
Default Re: Interior Problem (Hooch at 8400-RPM)
Old Nov 13, 2002 | 10:25 AM
sackdz's Avatar
Default Re: Interior Problem (AfterMath_DC2)
I have the same issue. The fabric from the factory is glued to a foam underform. Be careful what adhesiv you use, as the fabric is very porous and is really just mesh, the foam underneath is black. The adhesive I was recommended is 3-M Super-Somthing. It's a spray, and I was told Menard's carries it.
HTH
sack-who hasn't gotten around to fixing it yet.
Old Nov 13, 2002 | 10:40 AM
Chris_R's Avatar
Default Re: Interior Problem (sackdz)
HTH
Thats what I was originally thinking. Some kinda spray adhesive. Its not coming out real bad, I just noticed it had come loose so I just used my hand to work it back into position, and its stayed like that so far, but I want a permanant solution.
Old Nov 13, 2002 | 10:41 AM
Chris_R's Avatar
why does the fabric on your door panel look maroon?
I dont know. It was the camera
Old Nov 13, 2002 | 11:41 AM
Q-OnE's Avatar
yup....take the panel off and check the back seem. if it just needs glue or maybe a little DIY sewing will take care of it
Yukioh
Aug 30, 2012 10:17 AM
accordbaby06
Jul 28, 2006 12:02 PM
SILVER97EX
Jul 19, 2006 04:49 PM
Civicboy
Honda S2000
Jul 7, 2004 10:11 AM
Quik89Si
Jul 5, 2002 08:56 AM
