Injector Clip Retainer
I believe I have Prelude VTEC injectors in my car and I would like to get rid of these bootleg zip ties that hold down the clips. Does anyone know where I can get them? I'm assuming there is a metal clip that would secure it down? Just curious what are these clips called? (e.g. EV1?) The injectors are Keihin. Any info is appreciated!
I am not sure you can buy just the metal clips for your fuel injector plugs... you will likely have to purchase a set of the fuel injector plugs and simply rob the metal clips from them and place them on your current injector plugs. Remember that you will need the same type of plugs to get the clips from... OBD-0 style metal retaining clips are slightly different than those found on OBD-1 grey style plugs.
I talked to the seller and sent him some more pics. Evidently I have an OBD0 plug. From reading old honda-tech posts from the previous previous owner, it should have Prelude injectors. I made the assumption it was from a 92+ Prelude, which should be OBD1/OBD2 no?
This is what I bought: https://www.ebay.com/itm/38912608729...torefresh=true
Panoply
Jul 18, 2005 09:36 AM
