IGNITER PROBLEMS??
Old Dec 31, 2005 | 06:03 PM
jcektyper's Avatar
Default IGNITER PROBLEMS??
I have a 96 spec jdm type R motor. After completing the swap and installing the digital ignition (crane cam) the car ran really good then all of a sudden the car is running reallt bad. The tach is dancing around and the car is sputtering off and on?? Any suggestions on this?? My friend told me it could be a fried igniter. Any thoughts on this would be appreciated. Thanks in advance...
Old Dec 31, 2005 | 06:34 PM
Mythias's Avatar
Default Re: IGNITER PROBLEMS?? (jcektyper)
Try the hybrid forum. You made three posts in the ITR forum about your hybrid, and all three would be better suited elsewhere or nowhere at all.
Happy new year.
Old Dec 31, 2005 | 08:37 PM
DvD3's Avatar
B A N N E D
got a check engine light ?
Old Dec 31, 2005 | 10:19 PM
itralex's Avatar
I had the same problem with my R, it had around 100,000km on it and the ignitor crapped out the same time. I had the same symptons, motor crapping out and stuttering tach
the ignitor is a easy fix, however it is not cheap. I believe the ignitor itself is around 150usd from LEN.
Replacing the ignitor is really easy if you take out the distrubutor from the motor. once the distrubutor is out, you'll need to remove the cap and rotor to gain access to the ignitor. The ignitor is held in by 2 bolts on the outside of the distrubutor, just unscrew those and remove the female connectors (I believe there is 4 connecters) then the ignitor slides right out with ease
Old Jan 1, 2006 | 12:49 PM
jcektyper's Avatar
Default Re: IGNITER PROBLEMS?? (neo_)
Sorry to **** on personal site, next time I'll try and respect this issue... You ******* HOMO! That goes for that gay little white boy in CT. as well...******* grow the expletive up, if you don't have anything constructive to say, go back to banging your boyfriends and drinking your pretty pink virgin daiquiri.
bkmc24
18
Jul 23, 2007 10:02 AM
dpharand
Nov 11, 2005 06:26 PM
AMChev
Nov 1, 2005 05:49 AM
gsrvx
Mar 24, 2003 05:08 PM
blacksheep
Oct 14, 2002 06:12 AM
