idle problem
Old Sep 10, 2005 | 10:27 AM
tat2oed's Avatar
Default idle problem
I recently bent all my exhaust valves and tore down the head and rebuilt it to stock spec. After i did all this i replaced the stock throttle body(with a 70mm)intake maniflod, and the fuel rail (with a high flow fuel rail). Now i am having problems with the engine idling. It bounces up and down. Sometimes it idles around 1500 rpms sometimes it idles at 100 rpms then stalls out. I have adjusted the idle screw but then i throw a light for the system being to rich. Any info would be awesome.
ps anyone know how to reset the maintence required light?
Old Sep 10, 2005 | 11:06 AM
ZygSpeed's Avatar
Default Re: idle problem (tat2oed)
Stock ECU?
Aftermarket fuel management, or both?
Old Sep 10, 2005 | 11:17 AM
Jowee's Avatar
Idle problems are commonly known to happen with aftermarket throttle bodies. What brand do you have and is it calibrated correctly? Try getting a can of carb cleaner and spraying around your throttle body and intake manifold and see if it causes the engine to die out. If so, you have a leak.
Maintenance light is under the driver side dash. Look for the blue button. Put the key in the start position and hold the button down for a few seconds and it should go away.
Old Sep 10, 2005 | 07:53 PM
tat2oed's Avatar
Default Re: idle problem (Bryce Lynch)
aem high flow fuel rail -stock ecu
Old Sep 10, 2005 | 07:54 PM
tat2oed's Avatar
you say i might have a leak. a vaccum leak or some other type of leak
Old Sep 11, 2005 | 11:27 AM
PURPLETERROR aka BIGMATT's Avatar
the fuel rail was a waste of money, and the 70 mm tb is overkill. It sounds like your tps is out of adjustment, it should read .5 volts closed 4.5-5v wide open
Old Sep 11, 2005 | 05:55 PM
tat2oed's Avatar
Default Re: idle problem (PURPLETERROR)
y u say fuel rail waste of money?
Old Sep 12, 2005 | 07:20 AM
Jowee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tat2oed &raquo;</TD></TR><TR><TD CLASS="quote">y u say fuel rail waste of money?</TD></TR></TABLE>
Because it is......
Old Sep 12, 2005 | 07:59 AM
Dave_B's Avatar
How do the plugs look. My car was just having an idling problem where the tach would bounce, luck would have it I replaced my plugs with some Denso's. My car is stock though.
Old Sep 12, 2005 | 11:11 AM
ericlee303's Avatar
I had the exact same problem after I rebuilt the head on my old teg. However, I used the stock throttle body and fuel rail.
I susped the TPS is malfunctioning, or the TB is not calibrated properly. I tried cleaning it, but no results.
Old Sep 12, 2005 | 03:14 PM
tat2oed's Avatar
Default Re: idle problem (Jowee 1162)
hell of an answer. i wasnt really argueing with that statement i was just wondering what someones opinion was of the fuel rail.
Lss1six
May 6, 2017 09:11 AM
ben1284
Feb 18, 2008 06:17 PM
nigtron
Jul 12, 2007 03:11 PM
DShowers
Dec 3, 2004 09:30 PM
Ideal
Aug 22, 2002 08:51 PM
