icebox install ?
Old Feb 22, 2003 | 10:43 AM
YellowR2000x2's Avatar
Default icebox install ?
So i installed my icebox today and i love the OEM kind of look to it, but my only concern is the lower air horn...it just doesnt feel...secure...i installed the metal bracket and lined up and tightend the c-clamp as much as i could but it just doesnt seem like it holds it on there very well, im just concerned ill be driving and it will just wiggle its way off..anyone have any similar concerns or thoughts on this problem? thanks!
Old Feb 22, 2003 | 11:06 AM
Smitdog's Avatar
Default Re: icebox install ? (YellowR2000x2)
If u installed the clamp proberly and the C-Clamp as tightly as you can then i should be fine. Just check it to make sure it is always attached. Mine came off once and i honestly could tell the difference in performance. No biggy just keep an eye on it.
Old Feb 22, 2003 | 11:15 AM
GRM Scott's Avatar
25 Year Member
i crammed some big o-ring material in there, i think i've got pix on S&M...check tha link in sig.
Old Feb 22, 2003 | 01:43 PM
Tweakmeister's Avatar
Default Re: icebox install ? (Aleph)
mine _used_ to fall off often...
I finally got it right...just make sure it's really tight.
Old Feb 22, 2003 | 05:04 PM
kkim's Avatar
you could try wrapping a piece of duct tape around the joint. that's pretty much how the mugen intake holds the horn on.
I had an icebox on there before the mugen, but never had any problems with it coming off.
Old Feb 22, 2003 | 07:22 PM
vtec.dc2's Avatar
you don't even need to use the clamp to have it secure - problem with icebox - it traps water from beind the turn signal.. as long as you have the clamp installed you could fit the the lower horn over both clamp and upper piping, you want to raise the car in the front and take out turn signal - to see better.
if you want to use the clamp - make sure its tight enough or it will come loose and fall off.
Old Feb 22, 2003 | 07:33 PM
rodimus's Avatar
Default Re: icebox install ? (vtec.dc2)
my **** kept falling off too.
i just leave it completely off like i do when it rains
when i get off my lazy *** i'm gonna uninstall it...
wrap the intake with something like tape so the lower
arm is a more tight fit.
imo the o-ring provided is a hair too big.
Old Feb 22, 2003 | 07:38 PM
vtec.dc2's Avatar
Default Re: icebox install ? (EVOL)
i tried tape but my last method (mentioned above) works perfectly and easy to uninstall when needed
B16DelSlo
Mar 17, 2009 08:01 PM
ArizSun21
Jun 26, 2003 09:04 AM
hatchdrvr
Jun 14, 2003 06:44 PM
disordeR
Apr 15, 2003 12:42 AM
FULLTHROTTLE
Honda S2000
31
Jun 23, 2002 10:05 AM
