i can't decide on an engine setup....
Old Mar 15, 2002 | 10:08 PM
GoodFella's Avatar
Unfortunate Clevland Sports Fan
Default i can't decide on an engine setup....
ok heres my dilema....i dont know what the hell i want to do with my engine...i have 2 setups im looking at. My quetion is what setup do think is better. life of engine, daily driving, ect. ect. heres the setups im looking at...heres what i have already on the car...
comptech header, hi-flow cat, and exhaust
fuel rail and regulator
aem cai
v-afc
and heres what im looking at
setup #1
DRAG 3 turbo kit
apexi turbo timer
missing link
J&S safeguard V2
cluthmaster stage 3 clutch
clutchmaster light flywheel
eagle rods
JE 9:1 pistions with rings
RC 310cc injectors
total price = $5599.95
setup #2
toda spec b cams
toda valve springs
titanium retainers
stiffer inner springs
forged pistons 12.3:1 or around that
clutchmaster stage 3 clutch
total price appx: $3400.00
let me know what you guys think im torn between the two...thanks for any help you can provide
Old Mar 15, 2002 | 10:15 PM
seek167's Avatar
Default Re: i can't decide on an engine setup.... (GoodFella)
if it was me i'd stay all motor .you have a type r. it's intended for all motor use.
good luck with what ever you chose. also maybe throw a, ats final drive. in set up 2
[Modified by seek167, 2:17 AM 3/16/2002]
Old Mar 15, 2002 | 10:17 PM
B2FiNiTY's Avatar
All motor power
Old Mar 15, 2002 | 10:18 PM
01-1293's Avatar
yes.....i agree......the type r was designed based on natural aspiration........no matter how much you modify.......this engine wasn't meant to have forced induction.......in my opinion i would go all motor.......
hybrider's Avatar
Default Re: i can't decide on an engine setup.... (seek167)
plz do stay n/a
Old Mar 15, 2002 | 10:21 PM
GoodFella's Avatar
Default Re: i can't decide on an engine setup.... (hybrider93)
thanks for the replies...what whp output do you think i will achieve with each setup?
n/a vs FI....i know the FI will be more but what do you think the n/a will get?
Old Mar 15, 2002 | 10:23 PM
seek167's Avatar
i'll take a guess a set up 2 and say 200whp. i'm not as good as the other guys . so don't flame if i'm wrong
Old Mar 15, 2002 | 11:00 PM
SpoonCivic's Avatar
New User
you can get around 210+ if u change ur header..maybe buy an SMSP or Hytech header..cuz with the high compression and big cams lobes, u'll need a better header then the comptech for sure.
Old Mar 16, 2002 | 07:41 AM
GoodFella's Avatar
Default Re: i can't decide on an engine setup.... (SpoonCivic)
thanks for the help....what do you think that turbo setup could put out and at a safe psi with the stuff im getting?
Old Mar 16, 2002 | 08:53 AM
madx's Avatar
go n/a
Old Mar 16, 2002 | 09:00 AM
StinkyTofu's Avatar
Default Re: i can't decide on an engine setup.... (madx)
What do you want to do with your ITR? If it is straight line performance i would go for the turbo set up you listed. If you want to auto-x your car then definitely stay n/a.
I'm guessing you could make well over 300 whp with the turbo set up you listed. Just depends on how much boost you want to run. How about a supercharger?
Old Mar 16, 2002 | 09:19 AM
GoodFella's Avatar
Default Re: i can't decide on an engine setup.... (B-18c1)
well i havent really done any auto-x, ive been to the strip a few times....my bigger concern is for daily driving...i drive my car 30 miles one way. i know n/a would probably be better gas wise. but is staying n/a safer than if i were to go turbo?
as for the sc my brother had a jrsc on his and he didnt achieve much out of it and it gave him problems. id rather just stay n/a or go turbo
Old Mar 16, 2002 | 09:24 AM
BDiddy's Avatar
the turbo will be just as much of a headache. As some of the turbo mafia guys. Once its dialed in its a bat outta hell, but dialing it in is like going to hell and back from what I hear.
Id go N/A. Aftermarket turbo cars never impress me much. Its like wow, you couldnt build a motor so you had to cheat and add a turbo? Wussy. N/A all the way
Old Mar 16, 2002 | 09:34 AM
Misfit's Avatar
Default Re: i can't decide on an engine setup.... (B-DIDDYR2K)
Go B20 crvtec and stay NA. i am thinking of doing this.
Old Mar 16, 2002 | 09:37 AM
Tomakit's Avatar
If you are still having trouble deciding, drive cars similar to what you have in mind back to back...
Whichever you like more, NA or Turbo, do that.
Tom
(dialing in a turbo is not easy at all like b-diddyr2k said)
Old Mar 16, 2002 | 10:16 AM
b18cTurbo's Avatar
Default Re: i can't decide on an engine setup.... (Tomakit)
go fi 100% that the best satisfaction youl ever whanted in your life
you talking about tones of thorque and hp ,dont do the mistake i did before and spend your $$$ away
n/a
FI
do it NOW!!!
Old Mar 16, 2002 | 10:19 AM
StinkyTofu's Avatar
Default Re: i can't decide on an engine setup.... (mikvtec)
Well you can get a boost controller if you're worried about gas mileage. When you're driving to work just turn down the boost and when you wanna rip camaro *** then just boost it up. Sounds like you aren't really into tracking/auto-xing your car. If i were you i'd go turbo.
Old Mar 16, 2002 | 10:21 AM
b18cTurbo's Avatar
if you go fi dont put 310 cc go get some 440 it will work perfectly whit your vafc, get a block gard to
SpoonCivic's Avatar
New User
U'd prolly be able to go <= 15psi..as going more would require a standalone computer and solid sleeves.
I dunno about the gas being an issue. I used to have 11.5cr pistons in my car before I went turbo, and gas was about the same now as it is with my turbo.
U gotta remember the gobs of torque u have. If ur at 100km/h, ur at 35-4000rpm in 5th..u dont have to shift, just mash the pedal and the torque is right there for passing.
However, i will agree with most guys...going turbo and using it on a track is hard, i do it..and i vow that if the motor blows ever again i will go back to n/a.
Old Mar 16, 2002 | 10:23 AM
GokuSSJ4's Avatar
well if you go turbo , remember that for the full benifit of it your gearing is to short , at least gsr tranny with lsd or evn ls with lsd.
now R block are one of the strongest but yet design for N/A .if you want to achieve 210whp or more which im sure that yo would IMO include making it a 2.0l that way you gain huge TQ.
but also consider your goal ! what times in the 1/4 do you want to achieve ?? if you would be happy hitting 12's the go N/A but if you are aming for low 11's then think what you want from the car itself and also are you doing weight reduction and to what extreme !??
[Modified by Spoon1, 7:23 PM 3/16/2002]
Old Mar 16, 2002 | 10:33 AM
b18cTurbo's Avatar
Default Re: i can't decide on an engine setup.... (Spoon1)
i have a type r turbo pushing down 235whp at 7 psi a/f is perfect no detonation at all ive being running this setup for a while whit no prob at all
i still have the type r trainy whit an ls overdrive and i love it
i know a guy who made 13.5 1/4 mille and i beat him buy about 3 car
Old Mar 16, 2002 | 10:43 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
I say sell your ITR and get something else, then turbo it. I would never turbo my R but I would def. turbo a DSM or WRX, something with factory boost - or even a non-VTEC Honda. Just think that in addition to the $$ you'll spend on a turbo setup, you'll also have to swap out your tranny in order to take full advantage of it. Get an old Supra and boost that...you'll be destroying anyone in an ITR. If you've got the $$ to blow on that show car, just get something faster.
[Modified by Ross, 2:45 PM 3/16/2002]
Old Mar 16, 2002 | 11:44 AM
Mr. Softee's Avatar
Default Re: i can't decide on an engine setup.... (Ross)
Go turbo... make some real power.
Old Mar 16, 2002 | 11:48 AM
threatcon13's Avatar
New User
the R tranny is fine...all that BS about "staying in boost longer" is just that, BS.
Old Mar 16, 2002 | 12:46 PM
AllMotorITR's Avatar
New User
Default Re: i can't decide on an engine setup.... (ALLMOTORDC2)
Go with the Toda B Setup, or even a Jun 3 setup!
