Hytech Header
Old Mar 13, 2003 | 02:06 PM
capcon83's Avatar
Default Hytech Header
would the hytech header make the life of my motor die fast, or not last as long?
was wondering this because someone told me that the exhaust valves start to burn? i couldnt quit get what he was saying but i think thats what he said and not to get the header but i think hes just making me lagg on getting it
Old Mar 13, 2003 | 02:20 PM
Big Phat R's Avatar
Default Re: Hytech Header (capcon83)
you look like a dog and talk like one too
i think your friend is talking about reduced backpressure. exhaust valves will only burn if the car is running too lean - proper tuning will prevent this. whenever you put on a new exhaust system - care must be taken to make sure the car is still tuned properly.
Old Mar 13, 2003 | 03:04 PM
baonest1's Avatar
Default Re: Hytech Header (Big Phat R)
good deal. i have been curious too..
Old Mar 13, 2003 | 03:07 PM
Austin's Avatar
Now that's an interesting theory...I wonder where he came up with it.
Old Mar 13, 2003 | 06:34 PM
YelLowITR's Avatar
well.. hytech is one of the best i can think of, and if u want your car last long, all OEM parts will be the best. but still.. tunning is the point.
i think your friend is bsing u , i would get it if i have the money
Old Mar 13, 2003 | 08:59 PM
capcon83's Avatar
Default Re: Hytech Header (YelLowITR)
i have the money just enogh for the header but i wanted the exhaust system also.
my friend said get the header then get a resonator and then just mandro bend it to the side and little down so its not going to have a muffler just pipe but not long. just header then resonator and then little piping and then mandro bend it.
i dont know about that but i want the whole exhaust that hytech has he said everything with cat and muffler 2100 and i only have 1400
dont know if i should wait to get it all or get the header and work something out?
Old Mar 13, 2003 | 09:15 PM
SurferX's Avatar
Any 2.5" pipe will perform the same as long as it's mandrel bent and has no bottlenecks or anything else obstructing flow. Getting the HyTech exhaust is just nice because it's twin-loop, full stainless, TIG welded, and I think lighter in weight so it's quality stuff. But performance-wise, 2.5" is 2.5" so whatever sticker you want to slap on it won't make a difference on the dyno.
Old Mar 13, 2003 | 09:22 PM
capcon83's Avatar
Default Re: Hytech Header (SurferX)
my friend said no muffler just the pipe wouldent that be realy loud
Old Mar 13, 2003 | 09:45 PM
SurferX's Avatar
I'm taking a wild guess in saying that probably would be loud.
Old Mar 13, 2003 | 10:09 PM
Kelvin96GSR's Avatar
25 Year Member
yeah really freaking loud
Old Mar 13, 2003 | 10:11 PM
Reid's Avatar
Global Moderator
Maybe you shouldn't follow your friend's advice.
Old Mar 13, 2003 | 10:37 PM
SlayANT's Avatar
Default Re: Hytech Header (Reid)
oh great, more loud exhaust in sacramento, there goes my good night's zzz
Old Mar 13, 2003 | 10:41 PM
baonest1's Avatar
Default Re: Hytech Header (SlayANT)
any type of header will be loud as hail. and possibly kill you with the fumes too. , thats the best part
Old Mar 13, 2003 | 11:32 PM
YelLowITR's Avatar
well... better way is get the header, and go to exhust shop and custom pipes. that way u can save a lot money , and also it will give u good power too. straight pipe!!!!!!
Old Mar 14, 2003 | 02:24 AM
Ex-ITR5874's Avatar
Gets my vote
Old Mar 14, 2003 | 03:11 AM
urbanlegend21's Avatar
New User
Default Re: Hytech Header (ITR1858)
If your friend said jumping off the side of a bridge would be a cool thing to do would you jump?
Old Mar 14, 2003 | 04:34 AM
Brian*'s Avatar
Default Re: Hytech Header (George Knighton)
Headers can really lean the car out. That's what happened when I had the jdm R header on my Si. It failed emissions with a high NO level (twice the limit) which indicates high combustion chamber temps which is in turn caused by a lean condition. I added ~12% of fuel with my VAFC from 0-4000rpm (test range) and the NO level went from 1220ppm to 194ppm. So a header that has very good scavenging characteristics could cause very lean conditions and burn valves if the fuel remains untuned.
Brian
[Modified by Brian*Blue95M3, 5:34 AM 3/14/2003]
Old Mar 14, 2003 | 05:18 AM
b19coupe's Avatar
I had a muffler shop make me a 2.5" pipe from the cat to the muffler and it made the muffler sound like a coffee can. I bought a Type-R B-pipe and removed the bottle neck and then installed it. The car sounds stock and makes decent power; the resonator on the stock b-pipe makes a world of difference when it comes to noise levels.
Old Mar 14, 2003 | 06:15 AM
Ex-ITR5874's Avatar
Default Re: Hytech Header (Brian*Blue95M3)
Brian
wow, I thought Hondas fuelmap is always very rich when stock so a header itself couldn`t cause something dangerous... But wouldn`t I notice high knock rate before a valve gets burned ???
Old Mar 14, 2003 | 06:19 AM
Chris N's Avatar
Take all the money you have and go take a grammar/spelling class.
Mandro bent?
I had to read every sentence twice to understand!
Figure out what YOU want, why should we (or your friend) spoon feed you information.
Old Mar 14, 2003 | 06:20 AM
SurferX's Avatar
My car ran pretty rich before and after the header/exhaust system. My post VTEC fuel map needed to be leaned out. My partial throttle map is pretty rich too though, I'd like to get that tuned at some point.
JDM-h22a
Oct 13, 2009 06:57 PM
bigchain
Aug 22, 2008 09:17 PM
RGoose18
Jun 7, 2006 02:56 PM
RISING SUN 1
Apr 29, 2003 11:27 AM
crooked muffler
Mar 11, 2003 12:14 PM
