Hydrolock? Help!
Old Apr 12, 2002 | 02:37 PM
I Drive A Saturn's Avatar
Default Hydrolock? Help!
so i'm sitting at home today and my buddy (CW-ITR-329) calls me up and tells me his R just broke down. its raining and he thinks its hydrolock. he has an AEM CAI without a bypass valve and he tells me that he drove over a small puddle but not a three foot deep puddle either. well apparently after he drove over this puddle his R started to bog pretty bad so he let off and the thing just shut down. he tried to start it, but to no avail. is this hydrolock? is his R salvagable? i appreciate any insight you guys can give me.
-jeremy
[Modified by I Drive A Saturn, 11:51 AM 4/14/2002]
Old Apr 12, 2002 | 02:40 PM
reefer_bob's Avatar
Default Re: Hydrolock? Help! (I Drive A Saturn)
If a car hydrolocks, it does just that, locks. The water gets into a piston, and since water is incompressable, it won't allow the motor to turn... He prolly got water in the distributor... have him take it off, and dry the rotor, and plug wires and stuff. Use like a hair drier on the distributor and stuff...
Edit: I really need to learn to spell...
[Modified by reefer_bob, 4:01 PM 4/12/2002]
Old Apr 12, 2002 | 02:52 PM
IntegraT's Avatar
Default Re: Hydrolock? Help! (reefer_bob)
He prolly got water in the distributer...
I would agree.
Old Apr 12, 2002 | 03:15 PM
ITRacer121's Avatar
Default Re: Hydrolock? Help! (IntegraT)
It takes 2 cups of H2O to hydrolock a motor (AEM says so?) the rest is burned off when the motor fires
I would do what was previously said and pray for the best
good luck
Old Apr 12, 2002 | 06:53 PM
CW-ITR-329's Avatar
Default Re: Hydrolock? Help! (ITRacer121)
Ok, after working for 6 hours I went back to my car and turned it over. It started fine and all, but it is throwing a lot of black smoke out of the exhaust. Is it just burning the water out? Ryan
Old Apr 12, 2002 | 08:00 PM
csufweed's Avatar
Default Re: Hydrolock? Help! (CW-ITR-329)
uhh i think white smoke is water... black smoke is something else...
Old Apr 12, 2002 | 11:11 PM
uNF$@#!'s Avatar
Default Re: Hydrolock? Help! (csufweed)
stop using bacon grease to lube your valve cover gasket and the black smoke will disappear!
I'm just kidding.
white = water.
black... oil?
Old Apr 13, 2002 | 08:33 AM
EagleR's Avatar
Default Re: Hydrolock? Help! (00-0187)
white = water.
black... oil?
Thats what methinks too!
Old Apr 13, 2002 | 09:45 AM
b19coupe's Avatar
Default Re: Hydrolock? Help! (EagleR)
white=coolant,water
blue = oil
black = partially burned fuel (too rich)
[Modified by b19coupe, 6:46 PM 4/13/2002]
Old Apr 14, 2002 | 06:22 AM
CW-ITR-329's Avatar
Default Re: Hydrolock? Help! (b19coupe)
Ok, Havent driven the car cause I dont kno what to do. Its white smoke and at idle it sounds fine, just alot of smoke. What do I do to make sure everything is ok?
Ryan
Old Apr 14, 2002 | 07:56 AM
alright, for all of you who are interested in this problem CW-ITR-329 is having, here's an update: this morning, he started the beast up and let it idle for a while then he took it for a spin. no more smoke and it runs fine! now, he's prolly gonna replace his AEM CAI with a comptech icebox to completely eliminate the possibility of this happening again. what do you guys think about this?
-jeremy
Old Apr 14, 2002 | 07:58 AM
primoEF's Avatar
I guess you can take out the plugs and see what they look like, or blow all the water out from the chamber with the plug out
Old Apr 14, 2002 | 10:02 AM
mingchi96
Guest
Posts: n/a
Do a compression check and it will tell you everything.
Old Apr 14, 2002 | 10:04 AM
nfn15037's Avatar
Well, thats a gay reason to get a shitbox, but i want that CAI Rutter
Old Apr 14, 2002 | 11:57 AM
MK Ultra's Avatar
Default Re: Hydrolock? Help! (nfn15037)
Wow, pretty much that same thing happened to me a week ago, minus the black smoke. It was just a scare, but it was enough for me. Bye-bye AEM, hello DIY stock icebox.
You should do a compression test though. It's easy.
[Modified by MK Ultra, 2:58 PM 4/14/2002]
Old Apr 14, 2002 | 01:50 PM
designedforms98's Avatar
New User
How about this for hydrolock. My friend hydrolocked his b16a driving through a flash flood. I warned him.
Old Apr 14, 2002 | 02:04 PM
CW-ITR-329's Avatar
Default Re: Hydrolock? Help! (designedforms98)
How do you do a compression check?
-Ryan
Old Apr 14, 2002 | 02:11 PM
MK Ultra's Avatar
Buy a compression guage at any auto parts store. It screws into the spark plug holes.
Remove all the spark plugs, and disconnect the plug wires from the distributor. Spray some WD-40 down the spark plug hole. Screw the compression guage into the spark plug hole, and have someone hold the throttle all the way open and crank the engine over until the needle stops climbing. It will hold at the highest reading. Repeat for each cylinder, and write down the readings.
Old Apr 14, 2002 | 03:55 PM
01-1293's Avatar
Default Re: Hydrolock? Help! (MK Ultra)
I don't know what the hell you guys are doing........I've gone through pretty big puddles with absolutely no problems........the splash guard, the filter.........and a long *** tube.........you guys must be driving in ponds or something
Old Apr 14, 2002 | 04:49 PM
MK Ultra's Avatar
Default Re: Hydrolock? Help! (01-1293)
I've had AEM intakes for four years now.
Nothing remotely like this happened to me....until last week.
I too have driven through puddles before, many worse than the one that gave me such a scare. I couldn't believe what was happening, and the truth is, I don't know whether I got my distributer wet or if I may have sucked up just enough water to extinguish combustion, but not enough to actually lock the motor.
And I don't care.
My stock "cold air box" seems barely to have lost any power vs. the AEM, and that's with a crappy, old, stock paper filter. Once I drop in a K&N I suspect I'll have just as much power as before. And it's nice not having the extra noise.
And I'll not have to worry about hydrolock ever again.
Old Apr 14, 2002 | 04:52 PM
AllMotorITR's Avatar
New User
Just wondering, why do you always post for your friend? Why doesn't he post about his own car?
Old Apr 14, 2002 | 04:58 PM
CW-ITR-329's Avatar
Default Re: Hydrolock? Help! (1 FAST R)
That was my car, CW-ITR-329. And if you look above, I have posted 3 times in this post already. He has a Turboed Saturn that runs consitent 13's. There are no GOOD saturn boards so he posted and learns here. Give him break.
Old Apr 14, 2002 | 05:00 PM
2001silvergsr's Avatar
One of you Honda Tech "engineers" needs to come up with something better than the gay *** bypass valve. Maybe some sort of plastic sheet with holes in it but somehow not affecting air flow but stops water entry. HMMMM To bad Im not an engineer or Merlin the magician!
Old Apr 14, 2002 | 05:15 PM
Mike B's Avatar
Thats actually pretty cool how he posts here and drives a Turbo saturn.
CWITR329, he is just wondering duuude.
[Modified by Crazy Bovine, 8:17 PM 4/14/2002]
Old Apr 14, 2002 | 05:27 PM
CW-ITR-329's Avatar
Default Re: Hydrolock? Help! (Crazy Bovine)
I know, wasnt hating, just letting him know. No hard feelings!
