Is this a Hy-Tech header?
Old Oct 16, 2002 | 11:21 AM
rolow's Avatar
Default Is this a Hy-Tech header?
Just wondering if this bad boy is a Hy-tech?
Also what is the deal with the hose?
Old Oct 16, 2002 | 11:23 AM
8400 rpm's Avatar
Default Re: Is this a Hy-Tech header? (rolow)
Yea it looks crazy, Ericks Racing has something similar to that on their all motor coupe
(I think they sell em too)
[Modified by 8400 rpm, 12:24 PM 10/16/2002]
Old Oct 16, 2002 | 11:26 AM
IGGY's Avatar
Default Re: Is this a Hy-Tech header? (8400 rpm)
Looks like Hi-Tech, with the antireversion chambers.
That tube might be for some kind of backpressure.
Old Oct 16, 2002 | 11:29 AM
Bud's Avatar
Bud
New User
Default Re: Is this a Hy-Tech header? (IGGY)
The hose looks like the exhaust for a wastegate maybe?
Or maybe its some part of the emissions equipment
[Modified by Bud, 3:29 PM 10/16/2002]
Old Oct 16, 2002 | 11:32 AM
rolow's Avatar
My failed attempt to get a pic of Ericks header
Old Oct 16, 2002 | 11:35 AM
Rboosted717's Avatar
a wastegate! lol
Thats the Holland Racing (CBI) all motor car. And yes thats a custom Hy-tech header with a Megafone.
Also notice how low the header hangs. They say its because of the way the front is designed, the header needs to hang below it, however I think its also good for tripping the light at the end of the track instead of the front tire tripping the light. However one might think tripping the light early?? Yeah sure by what a few hundreaths of a second or a few inches. Look at the distance of the header vs. tire) of a second or so. Who would ever loose to them by that much.......
" (W) Cloyse Holland 111 ('90 Honda Civic) 0.668 11.491 120.57
(L) Lawrence Tse ('95 Acura Integra) 0.594 11.566 118.78
Holland was late off the line but with both cars coming close to duplicating their qualifying efforts he had enough in hand to drive by for a win margin of just 2 inches." -from NHRA
So I guess that custom HyTech header they have is good for more then just power...
[Modified by Rboosted717, 12:44 PM 10/16/2002]
Old Oct 16, 2002 | 12:43 PM
Trooper's Avatar
The black tube is a EGR valve.
Old Oct 16, 2002 | 12:48 PM
sgT's Avatar
sgT
Default Re: Is this a Hy-Tech header? (Trooper)
no
Old Oct 16, 2002 | 01:14 PM
xtrafastcivic's Avatar
Default Re: Is this a Hy-Tech header? (sgT)
the header is pretty low, but the lights at the track are only like an inch from the ground...
Old Oct 16, 2002 | 01:16 PM
sgT's Avatar
sgT
Default Re: Is this a Hy-Tech header? (XtraFastCRX)
more than that. maybe 2. theres a reason why regulations call for min 3" clearance
Old Oct 16, 2002 | 01:38 PM
put it this way. The header is so low that it trips the staging lights. If you watch them race you will see the staging light go on and off when the header trips it.
Old Oct 16, 2002 | 01:47 PM
Austin's Avatar
Default Re: Is this a Hy-Tech header? (Rboosted717)
Yep...which is why at the Sears Point/Infineon Raceway NHRA event they were raising the front end up before qualifying on Saturday in the event someone made a formal complaint...car was low again when they were at the Sacramento CMI race.
Austin
Old Oct 16, 2002 | 03:39 PM
slowerthanu's Avatar
New User
Default Re: Is this a Hy-Tech header? (Austin)
I get a cookie from SG-T The black hose is for there catch can setup, it pulls the vapors out and keeps crankcase pressure at the proper level.
Old Oct 16, 2002 | 03:40 PM
Austin's Avatar
Default Re: Is this a Hy-Tech header? (slowerthanu)
right you are...HyTech incorporates that into his setup as per the request of the race team that he is building the header for.
Austin
Old Oct 16, 2002 | 03:42 PM
Smitdog's Avatar
Old Oct 16, 2002 | 03:52 PM
SMSP's Avatar
This may be something that the car owners have set up with the suspension. It looks like the header was built that way based on the layout. Hytech needed to keep the tubes below the radiator to ensure proper cooling, but they needed to end the primary tubes quickly after they turn horizontal in order to have room for the rest of the header and tail pipe.
If the primaries came out of the head for a longer period prior to turning down, the secondaries would be smack in front of the radiator with air flow going across a main portion of the header (not good).
Any racer could falsely trip the lights at the finish with activation of a hydraulic suspension set up also.
I was not aware that crankcase ventilation like that was allowed in these drag classes. I'm about 100% sure that the SCCA doesn't allow it for road racing, since crankcase ventilation has to be routed to a catch can.
Old Oct 16, 2002 | 04:43 PM
SEFIxCivic's Avatar
that thing at the end should be a anti backfire valve. some old skool v8 technology that basically allows the exhaust to suck out the crank case vapors. its a one way valve that prevents things from flowing the wrong way.
[Modified by SEFI8LOxCivic, 1:45 AM 10/17/2002]
Old Oct 16, 2002 | 04:56 PM
Hooch'n's Avatar
Default Re: Is this a Hy-Tech header? (SEFI8LOxCivic)
Yes, I've seen that car with a Hy-Tech header on it at Gainsville NHRA Import event earlier this year, bad ***!
Old Oct 16, 2002 | 05:47 PM
New User
Actually, I am pretty sure what you are looking at is the flux capacitor, the anti backfire device (also known as a ONE-WAY valve) is located at the back of the engine were you enter the time coordinates.
RSciviX
Apr 18, 2010 08:45 PM
Big_Mike
Mar 26, 2003 06:36 PM
GreenR
Oct 9, 2002 07:32 PM
O1 Coupe
May 29, 2002 07:31 PM
