Hubcentric ring question??
Old Feb 7, 2003 | 07:47 PM
xjohnx's Avatar
Default Hubcentric ring question??
Hey, From what i understand ITR's need 73 x 64.15 mm hubcentric rings? Tirerack sent me 73 x 57.10's? will these still work? or no?
Old Feb 7, 2003 | 08:00 PM
vtec.dc2's Avatar
Default Re: Hubcentric ring question?? (xjohnx)
send them back.. is that what it says on the ring? measure it to make sure... the inner diameter should be 64.15mm... and 73mm.. - measuer the wheel yourself to make sure.. or try fitting the ring behind the wheel to see if it fits
Old Feb 7, 2003 | 08:05 PM
xjohnx's Avatar
Default Re: Hubcentric ring question?? (vtec.dc2)
hrm, looks like 73x64 when i measure it (well, very close to it anyway, i'm using a tape measurer). the reason i thought it was wrong was they sent me 2 sets, a plastic set that was included, and then the metal set that i ordered.
the plastic set had a 73x57.1 printed label on the package, and they're the same size as the metal ones (when held against each other)
the metal envelope had "64mm" hand written on it, i guess the plastic ones were just put in the wrong package.
guess i'll try and see.
Old Feb 7, 2003 | 08:08 PM
xjohnx's Avatar
ok, scratch that, the plastic ones are in fact 73x57.10's (57.10's is molded into it), but when comparing the inner diameters, there's definitely a difference, good thing i don't need the plastic ones anyway.
gosu08
May 28, 2009 02:49 PM
whatan00b
Jun 30, 2008 10:05 PM
AGS
Feb 2, 2005 01:11 PM
