HID <----help
Old Nov 12, 2001 | 08:19 PM
GettaluvR's Avatar
New User
Default HID <----help
yaya i know some ppl ask this b4 but i cant find it so please help me again
my left side lights looks a little bit higher then my right side ! the lights reflex on the gound, left side is about 20-30 cm further than my right side. i think the bulb is a little bit loose coz after i lock on the host i still can push the bulb to go up and down. should i just use rubber to make it tight or any other way ?
thx alot
and dont bitch me for this stupid q
Old Nov 12, 2001 | 08:27 PM
B2FiNiTY's Avatar
Default Re: HID <----help (itr-1030)
I had to use the rubbers off my old bulbs in order to make them fit tightly. Try it out.
tjtruong's Avatar
New User
OK thanks man!!! i just asked the question......hehehe thanks for responding the same time I was gonna ask the same thing........ ehehhe
[Modified by tjtruong, 5:28 AM 11/13/2001]
Old Nov 12, 2001 | 08:30 PM
Ghetto Racing's Avatar
New User
keep in mind that if your viewing from in the car then the beam pattern is not exactly the same for both left or right.
Old Nov 12, 2001 | 08:31 PM
GettaluvR's Avatar
New User
wow ppl here ansewer fast
thx
Old Nov 12, 2001 | 08:33 PM
GRM Scott's Avatar
25 Year Member
And you can adjust the horizontal and vertical aim of each light pod with a screwdriver, it's in the owner's manual i think too...assuming other tricks don't work.
Old Nov 12, 2001 | 08:57 PM
GettaluvR's Avatar
New User
Default Re: HID <----help (Aleph)
thx for help but i just went down and put the rubber on the bulb.....butbut it didnt help
and for the headlights adjustment i think it's not neccessory coz it's in perfect position. after i put the rubber i just need a liitle bit more to make it even. i dont wanna drive my car while i have use my finger to push down the bulb.
is it becoz driver side, higher makes it better ?
please help me. it looks ugly like that
[Modified by itr-1030, 6:02 AM 11/13/2001]
Old Nov 12, 2001 | 10:12 PM
GettaluvR's Avatar
New User
anyone ?
Old Nov 12, 2001 | 11:12 PM
RacingE_Teg's Avatar
I also put the old rubber rings on them and they still wiggled a bit. u have to make sure the rubber ring doesn't come off while inserting the bulb back in the housing.
After that, i still had to adjust my headlights...i only changed the height of the beams, not the direction(left/right). I used an 8mm wrench instead of a screwdriver b/c the screwdriver started eating into the plastic.
Old Nov 12, 2001 | 11:22 PM
B2FiNiTY's Avatar
Default Re: HID <----help (RacingE_Teg)
I used a screw driver to adjust my headlights too. I think acura is pretty stupid for making it plastic.
Old Nov 13, 2001 | 03:04 AM
Chaze*R's Avatar
Default Re: HID <----help (B2FiNiTY)
Yeah just use a phillips head screwdriver to adjust the angle of the beam. I did the same for my R cause they were aimed to low...could barely see 15 feet ahead of the car.
I strip the plastic each time i adjust it, too, but I don't do it offend so it won't be too bad.
-Chuck-
PS make sure you don't adjust too high, blinding the opposing traffic...i hate really bright beams from opposing traffic.
[Modified by Chaze*R, 4:05 AM 11/13/2001]
Old Nov 14, 2001 | 07:35 AM
itr0677's Avatar
New User
Default Re: HID <----help (Chaze*R)
Hmmm,
Another HID dilemma....
This is how I have my "final" setup due to problems, blah blah blah.
No rubber piece from old bulbs on new bulbs for the HID's.
Pulled the rubber cover on each headlight side out and inserted the HID bulb connected to the ballast connector. Took out my hot glue gun with "black" glue (the kind that withstands high heat) and glued around the bulb/ballast connector. Nice firm fit. The rubber pieces are then outward covering the ballast connector and zip tied around.
Will post pictures if people want.
The "black" hot glue stick is stronger than the clear and avoids issues. Can simply pull hard and peel away if needed (a bitch to do, but works).
- Brian
Danieliyo
Dec 19, 2011 08:27 PM
AhhNickk
Nov 30, 2009 12:12 AM
V-techpwr
Honda Civic (2006 - 2015)
Jan 26, 2009 04:53 AM
daveb91
Lighting
Dec 19, 2008 07:00 PM
Isaac
Jul 23, 2001 09:48 AM
