Help...Code 9...
Old Aug 16, 2005 | 02:52 PM
digital sol's Avatar
Default Help...Code 9...
99 jdm itr+p28 ecu+hondata tuned and all, was driving like a baby when my car started to stutter and then threw the check engine light, says code 9, 9 short blinks........
motor just has basic bolt on's, was dyno tuned, and only has about 20k miles on it
what is code 9, what causes it, what can fix it?.....car seems to bog and studder now at low rpm on my way home
Old Aug 16, 2005 | 02:53 PM
chad's Avatar
Moderator
Default Re: Help...Code 9... (digital sol)
get a new DIZZy....only fix
Old Aug 16, 2005 | 03:00 PM
Default Re: Help...Code 9... (chad)
wanna explain more? i dont just wanna go replacing things, ive replaced half of whats on the car as it is
the stock unit only has like 22k miles on it
also for reference, the guy who owned this motor before me was running msd digital 6, but i removed it because i didnt see the point in it
Modified by digital sol at 4:26 PM 8/16/2005
Old Aug 16, 2005 | 03:37 PM
also, is it ok to drive with this like this? or will it cause further damage on other parts?
thanks
Old Aug 16, 2005 | 05:48 PM
common guys, need your help
Old Aug 16, 2005 | 07:38 PM
TEiK's Avatar
check your harness jumper wire. it might have a loose conection. or put back your stock ecu to see if everything run fine.
Old Aug 16, 2005 | 11:35 PM
fastfour's Avatar
Default Re: Help...Code 9... (TEiK)
I had the same code last week. Head of the rotor screw broke off. Open up the cap and take a peek.
Old Aug 17, 2005 | 03:44 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Help...Code 9... (fastfour)
http://www.c-speedracing.com/faq/05.php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastfour &raquo;</TD></TR><TR><TD CLASS="quote">I had the same code last week. Head of the rotor screw broke off. Open up the cap and take a peek.</TD></TR></TABLE>
I agree. Also, go back over what you did to take out the msd, see if anything is messed up.
Old Aug 17, 2005 | 09:11 PM
Soichiro's way@MF's Avatar
Code 9 is the related to a distributor failure. the ckp sensor on the shaft inside the dist. is failing. they cant really be removed and rebuilt. replacing the distributor housing is the cheapest fix. Good luck
Old Aug 17, 2005 | 09:44 PM
Opie's Avatar
1) I Got A Code 9
2) Opened Dizzy
3) Saw This
4) Because of This
5) Did This
6) Bought New Distributor From Distributor King
Old Aug 18, 2005 | 03:41 AM
Default Re: (Opie)
problem fixed
my rotor was fucked, cap was fucked and a couple other little things were also fucked
replaced them all, started right up and runs better then ever, the screw became loose inside and did alot of damage, replaced all the **** that was damaged and now everything runs great
Old Aug 18, 2005 | 03:44 AM
cool guy name
Default Re: (digital sol)
good, glad you got it fixed.
rolledthatho
Dec 16, 2011 12:09 PM
76 camaro car
May 28, 2011 08:09 AM
joelmatt89
Dec 6, 2009 04:01 PM
2.3AccordSOHC
Jun 24, 2008 06:17 AM
