Help
Old May 19, 2008 | 09:46 PM
dx on the move's Avatar
Default Help
Hi how are you all doing? I have an 01 ITR, with 70k miles, bone stock. It throughs check engine code for too rich/too lean, want to know suggestions or information about fixing this problem. The car also idles rough once not rolling, it idels at around 600 rpms. Help please
Old May 19, 2008 | 10:51 PM
00-501itrspec's Avatar
Default Re: Help (dx on the move)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dx on the move &raquo;</TD></TR><TR><TD CLASS="quote">Hi how are you all doing? I have an 01 ITR, with 70k miles, bone stock. It throughs check engine code for too rich/too lean, want to know suggestions or information about fixing this problem. The car also idles rough once not rolling, it idels at around 600 rpms. Help please</TD></TR></TABLE>
If it is still stock why not take it to acura?
Old May 20, 2008 | 11:20 AM
wanted to see if it was something simple that someone else may have experienced.
Old May 20, 2008 | 11:58 AM
CW-ITR's Avatar
Sounds like a regular tune-up is needed. If a tune-up just done recently, check to make sure all fuel system connections are tight.
Old May 20, 2008 | 12:04 PM
BoBo Racing's Avatar
Default Re: Help (CW-ITR)
darrel ur throwing code 14 if im not mistaken correct? ne way i had that problem b4 but it was cause i was running rc 310 injectors dont know y ur motor would be doing that it its stock maybe 02 sensor is taking a crap or try using a chipped ecu all i did was mess around with the a/f with a street tune on got rid of it when u going to build somethin up already
Old May 20, 2008 | 01:18 PM
Did a regular tune up, i think it may the primary o2. any other suggestions.
kidcruze
Jul 18, 2008 01:45 PM
sickvtec
May 31, 2006 07:53 PM
MugenizedR
Nov 16, 2002 11:33 PM
NICHRIS143
Oct 28, 2002 09:09 PM
