height adjustability
Old Oct 27, 2008 | 12:07 PM
n1ghthawk's Avatar
Default height adjustability
I have stock ITR with 16/14 spoon coilovers. The question is, in theory, if I rise rear a bit, will car become more oversteered or understeered? center of gravitiy will move up front a bit so in my book that should be more undesteered and vice versa - if I lower rear a little more, teg should become more "tail happy" and I should do 180 turn a little faster. And same question goes for the stiffnes - I have 5 settings from 1 to 5 and I didnt try anything else than 1, as it is stiff enought as it is :D. My question is how does rear/front height and stiffess affect car beeing undeersteered or oversteered
I hope you know what I mean. I know some of you guys use you`re tegs on AutoX so you should know these things.
PS: where could I get adjustable rear swaybar endlinks? And I dont want those blox ones, I want oem desing if possible (to hold sway from both sides)...
Old Oct 27, 2008 | 12:12 PM
Bbasso's Avatar
Default Re: height adjustability (n1ghthawk)
Old Oct 27, 2008 | 12:16 PM
totsie7944's Avatar
Default Re: height adjustability (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
^ LMAO
To the OP, stiffer springs in the rear especially will give you more oversteer. Also keep in mind that shifting the weight to the front means that you have less weight pushing down on the back tires, hence one would think would grant you more oversteer as well. I am not an expert though
Old Oct 27, 2008 | 12:32 PM
get RIGHT's Avatar
Default Re: height adjustability (totsie7944)
I see where the OP is going with this I would suggest dialing in your oversteer by firming up the settings on your rear shocks and by playing with air pressures instead. Thats how I do it anyway.
Old Oct 27, 2008 | 01:01 PM
eluam's Avatar
Default Re: height adjustability (get RIGHT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by get RIGHT &raquo;</TD></TR><TR><TD CLASS="quote">I see where the OP is going with this I would suggest dialing in your oversteer by firming up the settings on your rear shocks and by playing with air pressures instead. Thats how I do it anyway.</TD></TR></TABLE>
I noticed with my car at Expo, with the rear end raised more than the front, that I had a little bit more oversteer. I also ended up stiffening my shocks to get a little bit more out of it.
I wouldn't worry about shifting weight by playing with the ride height, as you're better off playing with spring rates, sway bars, shocks, than with just raising and lowering the car.
Old Oct 27, 2008 | 01:19 PM
coolhandluke's Avatar
Default Re: height adjustability (eluam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eluam &raquo;</TD></TR><TR><TD CLASS="quote">
...I wouldn't worry about shifting weight by playing with the ride height, as you're better off playing withair pressures, spring rates, sway bars, shocks, than with just raising and lowering the car.</TD></TR></TABLE>
Old Oct 28, 2008 | 03:49 AM
Chris93Si's Avatar
Raising the ride height will increase the preload on the spring (effectively raising your spring rate). So raising the rear will result in more oversteer. HTH
kuja396
Mar 6, 2008 10:07 PM
Simon_the_Pieman
Nov 30, 2004 05:22 AM
96hb
May 8, 2004 09:03 AM
Integra4lyfe
Apr 15, 2004 12:41 PM
racekar
Feb 10, 2004 05:49 PM
