Header Question
Old Jan 15, 2008 | 06:25 PM
rpc08's Avatar
Default Header Question
I recently found a crack on my DC 4-2-1 Sport Header on my 98 R.
First off what could have caused this?
And what suggestions do you guys have for a replacement that won't break the pocket book? What brand header do you guys currently have on your car?
Someone suggested OBX, are those any good?
Any suggestions will help thanks.
Modified by nos86 at 7:58 PM 1/15/2008
Old Jan 15, 2008 | 06:32 PM
cmdr430's Avatar
Default Re: Header Question (nos86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nos86 &raquo;</TD></TR><TR><TD CLASS="quote">I recently found a crack on my DC 4-2-1 Sport Header on my 98 R.
a number of things could have caused it.....
i.e you went over a speedbump and possibly hit it......heat.......age..... etc. etc.
Any suggestions will help thanks.</TD></TR></TABLE>
how bad is the crack?
where is the crack?
can it be welded? that would probably be the least expensive route.....
pics?
Old Jan 15, 2008 | 06:51 PM
rpc08's Avatar
Default Re: Header Question (cmdr430)
it is cracked right where the third and fourth pipe join right where the weld is.
And thank you for your imput
Old Jan 16, 2008 | 05:19 PM
Aquafina's Avatar
Crap material, rust, heat, &lt; any of those + hitting something, resonance, running w/o an exhaust, etc.
Old Jan 17, 2008 | 10:30 AM
98 ITR's Avatar
With regards to an OBX header: don't waste your time. They're crap. I'll leave it at that.
If you want a budget header that will make power, the JDM Stainless 4-1 Type R header is a great choice.
Old Jan 17, 2008 | 11:13 AM
rpc08's Avatar
Default Re: (98 ITR)
That's what i ended up ordering JDM Stainless steel 4 -1 header last night.
Old Jan 17, 2008 | 11:31 AM
totsie7944's Avatar
Default Re: (nos86)
did you have springs where it bolts to the exhaust? sometimes when people disregard those springs, the movement of the exhaust can cause this.
Old Jan 17, 2008 | 11:51 AM
jomama's Avatar
eh, just wear and tear, i guess. ^ DC sports headers don't come with springs. only baller ones that the rest of you R guys are familiar with do. to the OP, time to get a jdm 4-1. it's a step up that won't break the bank roll.
EDIT: good choice on the selection.
Old Jan 17, 2008 | 12:00 PM
itr1244's Avatar
Default Re: (jomama)
if your exhaust system is too tight / solid and have no flex pipe. it could cause that.
or u hit something. or gaver too much so your motor moved alot. = warn motor mount?
Old Jan 17, 2008 | 12:23 PM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">eh, just wear and tear, i guess. ^ DC sports headers don't come with springs. only baller ones that the rest of you R guys are familiar with do.</TD></TR></TABLE>
If you're referring to the Toda, those do nothing at all and they are there only for show.
totsie7944 was talking about the springs on bolt at the end of the downpipe.
In this diagram, it is number 21 at the lower left.
Additionally, some people like to run the header without the brace attached or even go as far as removing the brace. Normally this is fine, but bare minimum, you should have some motor mount inserts for the rear mount to reduce/eliminate any rearward movement and the mentioned springs in the system to give it a little bit of flex.
Capo dei Capi
Dec 6, 2007 08:06 PM
sky82
Sep 29, 2007 12:02 AM
paowa
Jun 25, 2007 10:05 AM
96accordtypeS
Mar 6, 2006 03:42 PM
solfood
Jan 19, 2006 12:53 PM
