got a problem...HELP
Old Apr 17, 2006 | 06:30 PM
h0ndaDC2's Avatar
Default got a problem...HELP
hey guys.i need some help.i was driving on the highway today and there was traffic.all of a sudden i looked at the water temp gauge and it was going up.it kept on going up until i sped up then it went normal.it keeps doing that.i went to get it check but the mechanic doesnt even kno.and its not the fuse.any suggestions???DONT WANT THE R TO OVER HEAT!
Old Apr 17, 2006 | 06:32 PM
h0ndaDC2's Avatar
Default Re: got a problem...HELP (h0ndaDC2)
i meant its not the fuse** because the fan isnt spinning and the anti-freeze is full too.
Ed 341's Avatar
Maybe the thermostat is bad?
Old Apr 17, 2006 | 06:34 PM
Speed Infliction's Avatar
maybe your thermostat, and didn't you mean the fan IS spinning.
Old Apr 17, 2006 | 06:50 PM
h0ndaDC2's Avatar
i mean the fan doesnt spin at all.it use to spin when when the engine gets hott.now it doesnt spin.should i replace my thermostat?
Old Apr 17, 2006 | 06:55 PM
JjuuN R's Avatar
Default Re: (h0ndaDC2)
well, yeah you should but that has nothing to do with why your fans aren't coming on
Old Apr 17, 2006 | 09:31 PM
WickedKP's Avatar
did u check the fuse under the hood near the battery? Maybe the fan itself is stuck or bad fan relay? have you mechanic check the wiring near the fan plug. make sure he test for positive and ground when the engine warmed up.
Old Apr 17, 2006 | 09:48 PM
JjuuN R's Avatar
Default Re: (WickedKP)
OT: Wicked man i love your Avatar, keep it forever please
Old Apr 17, 2006 | 09:50 PM
NorthernXposure's Avatar
Default Re: (JUN.R)
mine has been doing the EXACT same thing... changed the thermostat, coolant+ water wetter... and still does it at a stand still.. pretty much narrowed it down to the fan not coming on... ill be dealing with that issue tomorrow on my day off
Old Apr 17, 2006 | 09:59 PM
HONDA RR's Avatar
Default Re: (NorthernXposure)
Change the fan switch or put a switch that reacts to a less temperature like the mugen thermostat switch.
Old Apr 18, 2006 | 06:08 PM
h0ndaDC2's Avatar
Default Re: (HONDA RR)
my heat and ac doesnt work...its not the fuse.what can it be???
f1fever
Apr 20, 2008 03:34 PM
vti444
Aug 22, 2007 08:51 AM
jeezyskillz
Nov 3, 2006 06:20 AM
B bOy CrAyOn
Jun 6, 2006 01:08 PM
Anthonyl469
Mar 18, 2003 01:48 PM
