Engine Slightly Knocking
Old Mar 13, 2006 | 04:58 AM
Crafte's Avatar
Default Engine Slightly Knocking
Hey everyone,
I'm new to the itr world, I just bought a used 1998. I hear a slight knocking when I pop the hood and let the car idle. I can't hear it while I'm in the car, just outside when I pop the hood. Anyone experts here have any advice? Should I worry about this? How can I fix this problem? Thanks.
Old Mar 13, 2006 | 06:40 AM
Bradstard's Avatar
Default Re: Engine Slightly Knocking (Crafte)
Are you sure it's knocking and not the valves tapping? Have you adjusted the valves at all recently? You might need to adjust your valves or if this is your first B-series motor you just aren't used to how loud they are at idle.
Old Mar 13, 2006 | 11:36 AM
nightrider's Avatar
get a valve adjustment. that's more likely than the previous owner over-revving and then selling it.
Old Mar 13, 2006 | 04:01 PM
mugenracer's Avatar
My injectors chatter quite noisily...are you sure its a knocking sound???
Old Mar 13, 2006 | 05:42 PM
JjuuN R's Avatar
Default Re: (mugenracer)
a slight tapping of the valves in C5 motors is normal, if it's more the a slight tap then get them adjusted, should get them adjusted anyway
Old Mar 13, 2006 | 05:59 PM
Tweakmeister's Avatar
these engines do make weird noises - could be A/C or Power Steering pumps too lol
b20integrapower
Feb 1, 2006 06:07 PM
wragen22
Apr 8, 2005 11:44 AM
Flux
Apr 15, 2004 07:25 PM
the.hamburglar
Apr 3, 2004 11:06 AM
lilxvtecxpwr
11
Sep 17, 2002 05:58 PM
