Engine knocking
Old Jul 12, 2002 | 05:03 AM
jond's Avatar
Default Engine knocking
Can someone post a mp3 or something with this engine knock people are talking about.
Mine makes a sort of knock at idle, and more so at idle with the AC on.....
Old Jul 12, 2002 | 05:24 AM
uNF$@#!'s Avatar
Default Re: Engine knocking (jond)
...did you advance your timing?
if you have your ac on, at idle and you hear knocking, retard the timing a little.
if your currently not throwing cel's, try retarding the timing anyhow. if the knocking stops you know your problem
Old Jul 12, 2002 | 08:19 AM
jond's Avatar
Default Re: Engine knocking (Soup ****)
No. I have changed the timing yet.
I am using texaco gas instead of my usual amaco. I wouldnt think that would matter unles the engine gets used to higher quality gas and advances the timing automatically...
Old Jul 12, 2002 | 08:49 AM
01PYITR's Avatar
some where on H-T there is a sound clip of a motor knocking search for it I had no luck.
Old Jul 12, 2002 | 09:23 AM
01PYITR's Avatar
http://www.jovialrobot.net/justin/files/headtap.mp3
Old Jul 12, 2002 | 09:24 AM
01PYITR's Avatar
Default Re: Engine knocking (01PYITR)
Hope this helps..
Old Jul 12, 2002 | 09:38 AM
Ex-ITR5874's Avatar
Hmm
that`s at idle... sounds like a diesel..
And how does it sound at 5000rpm ?? And how does it feel ?
Old Jul 12, 2002 | 10:06 AM
fubar's Avatar
Default Re: Engine knocking (ITR1858)
This may be a dumb question, but...what exactly causes your engine to knock? and if it does knock, is it reversible? if so, how?
Old Jul 12, 2002 | 10:24 AM
jond's Avatar
Whooa! Its not like that!
It sounds more like maybe something is lose or rattling against something, which hopefully is all it is.
Thanks!
Old Jul 12, 2002 | 10:25 AM
jond's Avatar
Sounds normal at 5,000
Still feels strong
Old Jul 12, 2002 | 10:51 AM
Ex-ITR5874's Avatar
Still feels strong
my ecu shows knock warning at 5000-5600 rpm.... I hear and feel nothing.
@furbar:
Knocking means self-ignition of the mixture... It can be caused by incorrect ignition timing, low octane fuel, too less fuel injection (lean mixture).
It`s also caused by high temperature in the cylinder and fawks up the engine if you do nothing against it.
You can take my explaination to get your points to be done to stop knocking
Old Jul 12, 2002 | 11:07 AM
01PYITR's Avatar
that sound clip is a bottom end knock which I hope you don't have (new motor needed) Have you checked the oil level in the motor?
To hear where the sound is coming from take a long long screwdriver and hold the end to the motor and the handle to your ear like a sethascope.. then move the end around the motor until the sound is at its loudest and see where it is and report back to us.
gooblinn258
Dec 12, 2013 06:21 PM
AnAccordIsForever
Nov 25, 2006 09:23 AM
josephshark
Jan 2, 2006 11:52 AM
01PYTypeR#1140
Jul 17, 2001 07:05 AM
