Engine Code 17 / VSS (Vehicle Speed Sensor) Problem
Old Aug 26, 2003 | 08:14 AM
alai2001's Avatar
Default Engine Code 17 / VSS (Vehicle Speed Sensor) Problem
I've been having problems with my ITR under full throttle in first gear past 4-5k prm (and basically any other gear under full throttle at high RPMs) where by the car basically cuts off all throttle input until I let off the peddle for at least around a 1/4 to half a second. Basically, the check engine light comes on and then the car stops accerating, and as soon as I let off the gas for a 1/2 second, the engine light disappears and I'm running again with no problems.
I buddy of mine at an autocross helped me get my engine code (thanks miles) and it gives me a Problem Code 17 (AKA: VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor).
Anyone have any ideas as to what might be causing this? I'd appreciate any advice you might have on the problem.
FYI: I have a hondata S100 dunno if that has anything to do with it, here are the rest of my mods engine and braking mods btw, I have no idea if any of it has anhything to do with the code but here it is anyways:
Engine Modifications:
Spoon B18C Fully Built Block
- Spoon 11.3:1 Compression Pistons
- Spoon Forged Rods
- Spoon Balanced Crank
- Spoon Oil Pump
Comptech 65mm Throttle Body
Comptech Port Matched & Polished Cylinder Head w/Stainless Valves
Comptech Stainless Steel Header
Comptech Port-Matched Polished SS Exhaust
Comptech Polished Intake with High Flow Filter
Comptech Ice Box
Comptech High Flow Fuel Injectors
Comptech High Flow & High Volume Fuel Pump
Comptech 6.75lb Lightweight Aluminum Flywheel
Random Tech High Flow Cat
ACT Xtreme Pressure Plate
ACT Organic Performance Disk
Skunkworks Red Anodized Cam Gears
Hondata S100 ECU Tuned by DynoSpotRacing, CA
Braking Modifications:
Stoptech 13" Front Rotor
Brembo 4-piston Calipers
NSX 11.3” Cross-Drilled and Vented Rear Rotors w/NSX Calipers
Porterfield R4S High Performance Brake Pads
Goodridge Stainless Steel Braided Brake Lines
Old Aug 26, 2003 | 08:19 AM
vtec.dc2's Avatar
Default Re: Engine Code 17 / VSS (Vehicle Speed Sensor) Problem (alai2001)
not sure how to fix it.. you could try to unplug/reset ecu and see if it comes back again..
if your car ever shut off due to low idle, it might throw random codes..
Old Aug 26, 2003 | 08:23 AM
alai2001's Avatar
Default Re: Engine Code 17 / VSS (vtec.dc2)
Doh, thanks for the tip. The car actually DOES stall under low idle sometimes -- esp. on startup.
I wonder if that might be a random code?
Old Aug 26, 2003 | 09:00 AM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alai2001 &raquo;</TD></TR><TR><TD CLASS="quote">
I buddy of mine at an autocross helped me get my engine code (thanks miles) and it gives me a Problem Code 17 (AKA: VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor).</TD></TR></TABLE>
Well, the code says the VSS is either not working properly or is unplugged.
Did you check that yet?
Old Aug 26, 2003 | 09:03 AM
vtec.dc2's Avatar
Default Re: Engine Code 17 / VSS (alai2001)
it could be.. if your speedometer working fine before this.. try the easy way first and see if it comes back..
Old Aug 26, 2003 | 10:08 AM
B18C5's Avatar
Haha. If that's the same Miles you definitely went to the right guy to help look for electrical gremlins. LOL. VSS is a pretty brainless sensor, but it shouldn't cause many problems other than making the car run in limp home mode. Unless you're running an OBD 1 ECU. Something like that... but I'm not an ECU ***** so I dunno fo sho.
I'm mostly just wondering... did you tune the car in CA or did they just send you a program? Cuz there are a couple local hondata guys who might be able to help if it's a tuning problem. Maybe try running a stock ECU just to see. Your mods are extensive, but at least you don't have cams.
Old Jun 19, 2004 | 10:21 AM
Firewerks's Avatar
Default Re: Engine Code 17 / VSS (B18C5)
Check your actual connection at the ECU, its on the middle plug and its an orange wire (if i remember correctly) make sure it hasnt come undone.
muasboi
Mar 31, 2009 06:30 PM
nelson69
Oct 30, 2005 05:13 AM
Fatty_1775
Jul 25, 2003 04:52 PM
si91
Jul 9, 2002 09:15 AM
Civicdrgrcr
Jul 4, 2002 05:52 PM
