Engine cleaner?
Old Jun 24, 2002 | 04:26 PM
Champ R's Avatar
Default Engine cleaner?
Just curious to what you guys use to clean the engine and engine bay. Im going to give the R a full wash/interior scrub and would like to know whats best for under the hood. Thanks.
Old Jun 24, 2002 | 04:27 PM
Willard's Avatar
Default Re: Engine cleaner? (Champ R)
I use regular soapy water.
Some people use diluted Simple Green cleaner...
Old Jun 24, 2002 | 04:28 PM
RaVAGE00's Avatar
New User
simply green.... works well. safe on most any surfaces. I use it.
Leo's Avatar
Leo
Plain Simple Green + a rag + a hose = clean as hell..............
After it's dry, put armor all on the hoses. They get shiney and keep from getting old looking.
Old Jun 24, 2002 | 04:30 PM
vpc's Avatar
vpc
New User
Default Re: Engine cleaner? (ITR 01-0166)
Thats almost what I do. I'll spray down the entire bay w/ a bottle of Simple Green..i'll spray extra on spots that are dirtier. I'll let it sit for a couple of minutes and then hose it all down thoroughly. I'll wipe dry and then go thru with Armour All on all the hoses.
Old Jun 24, 2002 | 04:31 PM
Leo's Avatar
Leo
Default Re: Engine cleaner? (vpc)
Old Jun 24, 2002 | 04:33 PM
jetydosa's Avatar
25 Year Member
I use Meguiar's EXTRA All-purpose cleaner or Simple Green.
Old Jun 24, 2002 | 04:40 PM
kkim's Avatar
QUOTE]Plain Simple Green + a rag + a hose = clean as hell..............
After it's dry, put armor all on the hoses. They get shiney and keep from getting old looking.[/QUOTE]
that's what I use... also, a 3" wide paint brush to get the really hard to reach places when washing with the simple green.
Old Jun 24, 2002 | 04:56 PM
tjtruong's Avatar
New User
Default Re: Engine cleaner? (kkim)
me too
Old Jun 24, 2002 | 05:01 PM
Champ R's Avatar
Default Re: Engine cleaner? (tjtruong)
Cool thanks for the replies.
Old Jun 24, 2002 | 06:14 PM
csfalcon's Avatar
you all just hose the engine bay down? can you give me some details on how to clean under the hood and what to watch out for? thanks!
Old Jun 24, 2002 | 07:36 PM
Willard's Avatar
Default Re: Engine cleaner? (csfalcon)
I cover the valve cover and distributor with plastic... other than that.. I spray all of the engine.
Old Jun 24, 2002 | 08:37 PM
vpc's Avatar
vpc
New User
I'd be careful w/ any thing that can be prone to water damage like the distributor. One of the most important things is to ONLY HOSE DOWN THE ENGINE WHEN IT IS COMPLETELY COOL. Engine Heat + Cold water = Bad idea Otherwise I don't take very many precautions. I just start spraying away...I tend to target the heat shield on my header cuz it gets dirty easy...any parts of the engine block that has crevaces where dirt can collect, the tranny casing, top of the intake manifold, and the firewall. Oh and I also spray the underside of the hood cuz a lot of grime likes to cling to it as well. Also one other note....depending if there are any modifications...don't get your air filter wet.
Oh...I also spray my undercarraige and wheel wells too.
I am a cl3an-wh0re.
Old Jun 24, 2002 | 09:21 PM
01PYITR's Avatar
Before you asked this question did you try the search , its located on the upper righthand portion of the screen?
SIMPLEGREEN is the perfect engine cleaner, it does not harm anything that I know of and cleans like a ****!
EDIT: Clean it hot or clod and if you put the stock ingition in properly or never touched it don't even bother with covering it, Hondas in stock form are 99.9% water tight ( some might say other wise).
[Modified by 01PYITR, 1:23 AM 6/25/2002]
Old Jun 24, 2002 | 09:45 PM
rainmanEK's Avatar
big strong guy
Default Re: Engine cleaner? (01PYITR)
gunk, works great spray on spray off! i use it every oil change! good luck, eric
Old Jun 24, 2002 | 09:46 PM
TeamTooQuick's Avatar
Default Re: Engine cleaner? (rainmanEK)
i second that....
Old Jun 25, 2002 | 04:37 PM
Edwin's Avatar
I use a mysterious blue liquid in a K&N filter dispenser.
That some good stuff. Thanks Johnnyboy!
Old Jun 25, 2002 | 04:53 PM
BABY NSX's Avatar
Default Re: Engine cleaner? (Edwin)
You guys and your fancy cleaners
All elbow grease babies!!!
[Modified by BABY NSX, 5:58 PM 6/25/2002]
Old Jun 25, 2002 | 05:02 PM
Edwin's Avatar
Default Re: Engine cleaner? (BABY NSX)
Haha nice.
Old Jun 25, 2002 | 05:18 PM
bakasan's Avatar
Old Jun 25, 2002 | 05:40 PM
ALL THINGS R's Avatar
Default Re: Engine cleaner? (bakasan)
Basically here are the steps that detailers use:
1. Engine should be warm but not hot (should be able to touch header heat shield)
2. Plastic wrap distributer, air filter and other areas that should not be wet (plastic wrap and 3m tape work well together.
3. hose engine down to loosen dirt and moisten area to clean.
4. Spray on a healthy amount of degreaser (I use a product called SLAM made by Production)
5. Use a mit and car soap to scrub stubburn areas (a brush might help).
6. Rinse off the degreaser and dirt
7. Thoroughly dry the engine and remove all plastic wrap.
8. I finish it off with a product called Stoner Spray and Shine to brighten up the rubber and platics ( much easier than wiping everything down.)
That should do it, good luck!
Old Jun 25, 2002 | 07:54 PM
dextR's Avatar
I use dirt
Old Jun 25, 2002 | 09:50 PM
Black DC2's Avatar
Default Re: Engine cleaner? (Thundarr)
lol (i use dirt)
Old Jun 27, 2002 | 01:01 AM
Darkteg's Avatar
New User
Default Re: Engine cleaner? (mighty goku)
pressurized soaped water pistol after washing the whole exterior. just make sure your car is running while you're doing it, and you're good to go.
you take 5 minutes of your time to clean the engine and inside the hood
Old Jun 27, 2002 | 03:33 AM
PYITR821's Avatar
Simple Green =
