Electrical Issues
Old May 21, 2010 | 07:24 AM
eurodeseo's Avatar
Default Electrical Issues
2001 Type-R symptoms:
1. Battery needs charged w/ an external charger often
2. Battery light is on at idle, but goes away as I throttle up
3. Recent screaching noise, like from a belt
4. Car won't start at all by the end of the work week (5 days)
I've researched as much as I can and it would seem that my alternator is going bad and I need a new belt. Would you all agree? And if so, where can I get these items fairly cheap? All the web searches come up w/ NSA and other off-brand alternators. Are these ok as a replacement or are they crappy?
Thanks.
Old May 21, 2010 | 05:44 PM
migs's Avatar
Default Re: Electrical Issues
I would personally get one from ebay.
73 shipped: http://cgi.ebay.com/ebaymotors/1996-...Q5fAccessories
98 shipped: http://cgi.ebay.com/ebaymotors/New-R...Q5fAccessories
Old May 21, 2010 | 06:33 PM
a97b18b's Avatar
seems like the alternator is going bad. Does the batt hold a charge?
Old May 21, 2010 | 07:00 PM
Steady R's Avatar
is the belt tight and in good condition?
Old May 24, 2010 | 09:32 AM
eurodeseo's Avatar
Originally Posted by migs
That one for $73 will work for a 2001 Type-R? I called about the $98 one and they told me it's not the right part. Excuse my ignorance, I don't know anything about alternators.
Old May 24, 2010 | 04:30 PM
Rush Racing Dev's Avatar
Check the basic stuff first like the battery connections and make sure they are clean. You can also spray the belt with belt conditioner to get you by for a while and possibly tell you if its just the belt. You could also stop by autozone and have them check out your alternator for free.
Old May 24, 2010 | 04:51 PM
Luchini's Avatar
1. Test to see whether your alternator is charging your battery.
2. If it is good check to see your battery is in good condition and fully charged.
3. If both are good something is draining your battery when your car is off.
4. Get a multimeter and run it in series with battery ground to see how many millamps of current the car is drawing from the battery while off. Compare with another Integra or shop. Make sure all accessories are off, door is shut, nothing is in 12vdc outlet.
5. If readings are higher then normal something is drawing too much current.
6. Pull fuses one by one and see if the current level drops. If it does its something in that circuit.
ElCivic89
Mar 27, 2012 08:23 PM
skipbudlong
12
Jul 24, 2009 03:03 PM
Tim 95 M3
Mar 12, 2009 02:17 PM
DmcL
Nov 30, 2006 07:28 AM
crxtreme27
11
Aug 28, 2002 11:29 AM
