Easy question??
Old May 29, 2002 | 09:32 PM
J.R.'s Avatar
Default Easy question??
Ok, Auto link motorworks in temple city put a b18c1 in my civic, Now, everything is good with the swap but here is my question. I went to change the cap & rotor, and when I took off the stock cap, I noticed writing on the distributor that said p73, Isn't that a type R distributor?? And my parts that I purchased for my ignition like the wires, plugs, and rotor are still going to work, even though the are for a gsr?Because the gsr cap that I purchased is too small, so I am pretty sure that it isn't even worth trying to put it on. So all i have to do is get a type R distributor cap right??
Old May 30, 2002 | 05:40 AM
madslackin's Avatar
Default Re: Easy question?? (96b18c1vic)
Cap/rotor/wires should all be interchangeable.
And how do you know the cap you bought is too small, yet you haven't tried putting it on yet?
Justin
Old May 30, 2002 | 12:17 PM
J.R.'s Avatar
Default Re: Easy question?? (madslackin)
Yes I tried putting the cap on, but it was too small. Unless they sent me the wrong cap???
Old May 30, 2002 | 12:20 PM
sgT's Avatar
sgT
probably the wrong cap.
B16a/b17a/b18c all the same
Old May 30, 2002 | 03:50 PM
J.R.'s Avatar
Default Re: Easy question?? (sgT)
The cap fits on my brothers b16, So if they are all interchangable, then why wouldnt it fit on my b18c1. Would a type r distributor require a different cap??
sgT's Avatar
sgT
Nope.
Im using a b16a cap right now
Old May 30, 2002 | 03:55 PM
reefer_bob's Avatar
Make sure you buy a honda cap, cause aftermarket ones tend to not fit well, or be pos's... I've seen a number of aftermarket caps go bad, or just not fit well. This even goes for quality aftermarket caps...
Old May 30, 2002 | 04:05 PM
spoon_ek9's Avatar
Default Re: Easy question?? (reefer_bob)
i just know there is difference between a LS and vtec motor, coz i just changed one yesterday. the non-vtec one is smaller.
legendre
Nov 7, 2013 03:00 AM
Paperclip1
Oct 27, 2006 10:48 AM
R249
Jan 10, 2003 08:20 PM
J.R.
May 29, 2002 03:02 PM
GRM Scott
Mar 1, 2002 04:41 PM
