Downshifting:heel/toe vs. rev matching....thoughts and comments
Old Dec 30, 2001 | 01:59 PM
  #26
MrBite's Avatar
Default Re: Downshifting:heel/toe vs. rev matching....thoughts and comments (Spikey)
When I rev match towards a stop light and find a great majority of people are brake light watchers. You know the type who only brake if they see red taillights. . They cannot judge distance or perspective for ****.. and will literally run into you if you don't tap on the brakes to show them the red taillights their so familiar with.
So be careful if slow down the car by rev matching and going down the gears.
You actually shouldn't (don't even need to) do this. Your brakes are efficient enough to lock up your tires, which is the most force you will ever need to slow down the car. Rev matching while braking is used to put you in the correct gear for the coming corner so you don't unsettle the car when you engage the clutch. I do practice heel-toe coming up to a red light, but only to practice the motions, not because it slows the car down.
Old Dec 30, 2001 | 02:00 PM
  #27
SiTEC's Avatar
that is an excellent point!
i tell my girlfriend this all the time, but does she listen.... NOOOOOOOOoooo
Old Dec 30, 2001 | 02:08 PM
  #28
Victor Penner's Avatar
Default Re: Downshifting:heel/toe vs. rev matching....thoughts and comments (SiTEC)
You shouldn't use the engine to slow down your car at all. You will be smoother if you use the gas to go and the brakes to stop. You also really do not have to double clutch the Type R for downshifts and don't say for first gear because that is only for driving through the pits.
Victor Penner
Old Dec 30, 2001 | 02:46 PM
  #29
ENDYN's Avatar
The Old One
Default Re: Downshifting:heel/toe vs. rev matching....thoughts and comments (Victor Penner)
In all the books on driving race cars that I've read, heel and toeing is a method for matching revs, allowing one to match revs for down-shifting while braking.
Old Dec 30, 2001 | 04:54 PM
  #30
Floyd's Avatar
Default Re: Downshifting:heel/toe vs. rev matching....thoughts and comments (frank@b16a.com)
there are two ways to heel-toe. you perform a simple revmatch, or you perform a full double clutch. read this thread from another board, we discussed it recently in details.
http://www.corner-carvers.com/forum/...ML/000576.html
[Modified by frank@b16a.com, 3:12 AM 12/25/2001]
For those of you too lazy to read the other thread..I found this post to be the most informative:
Rick's Speedy Transmixer Run-On: The clutch disk is splined to the input shaft which is geared to the countershaft which is simultaneously geared to the 1,2,3 and 5 change gears (in a T5) which spin at different RPMs while they freely revolve on the mainshaft (pant, pant). Synchros reside between the free spinning change gears and the mainshaft to provide speed matching during the shift. The input shaft lies inline with the mainshaft and can also be synchro engaged to the mainshaft, the 1:1 4th "gear¨ position. Shifting involves an ordered dis/engagement of the engine and transmission at the clutch, and the changing of gear ratios with the shifter. Changing gear ratios includes changing geartrain RPM, and the gear sets' synchro assemblies help narrow the change gear-mainshaft RPM difference and provide final splined gear-mainshaft engagement. During this short shift interval, the car's speed doesn't change much, and likewise the transmission's driven mainshaft RPM doesn't change much. After the clutch is reengaged (let out) the geartrain RPM change must be reflected at the engine's RPM.
Downshifting involves changing from a lower numeric ratio, say 1.0:1 (4th) to a higher numeric ratio, say 1.29:1 (3rd). This 1.29:1 ratio nomenclature means that the engine spins 1.29 revolutions for one mainshaft revolution when in 3rd gear. From the 1:1 4th gear direct drive RPM, the engine must spin up to this 1.29 times higher 3rd gear RPM at some point during the short 4th gear to 3rd gear downshift interval. Looking at the 3rd gear synchro relative speeds between 4th and 3rd gear is also instructive. While in 1:1 4th gear at 3500 engine/mainshaft RPM, the 1.29:1 free spinning 3rd gear sees only 3500/1.29 = ~2700 RPM. After the 3rd gear downshift, assuming the mainshaft is close to 3500 RPM still, the engine RPM must have increased to 3500*1.29 = ~4500 RPM. The 3rd gear synchro rose ~800 RPM to the mainshaft 3500 RPM level, while the engine rose ~1000 RPM.
Wish said
quote:
Cannon, that blip throttle is a downshift thing, and technically not needed with a double clutch, that's why you let the clutch out the second time to let the input shaft spin up to the same speed as the engine.
Sorry, but this confused me, somewhat more than normal I think double clutch downshifts add to synchro work UNLESS engine RPM is raised while the clutch is out to match the new gear's higher RPM. The double clutch downshift without blip throttle doesn't accomplish anything of value. For example: in 4th gear, the engine spins the input geared geartrain at some RPM. Letting the clutch out after disengaging 4th gear just reconnects the engine to the input shaft geared geartrain at the same or lower RPM in neutral instead of 4th. No Work is done, although you have exercised your leg. Since the closed throttle engine RPM probably drops faster than the mainshaft RPM, the double clutch alone may even INCREASE the 3rd gear-mainshaft RPM difference that the synchro must still overcome...
To complete a 4th to 3rd downshift, while in neutral, the 3rd gear synchro RPM must either be sped up by
the engine's blip throttle back through a clutch engaged input shaft, or
the mainshaft speed forward through the 3rd gear synchro and geartrain to the clutch disengaged input shaft (recalling that the mainshaft stays close to the previous RPM).
If you blip throttle with the clutch out while the transmission is in neutral, the engine spins up the geartrain back to the 3rd gear synchro. The subsequent downshift into 3rd can now take place with little RPM difference across both the synchro and the clutch; smooth, baby. If the mainshaft speeds up the 3rd gear synchro alone prior to downshift, then the synchro has done the heavy lifting while the RPM mismatch still exists. Congratulations, the synchro RPM difference has just moved upstream to the clutch. Letting the clutch out engaged in 3rd gear while traveling at 4th gear speeds forces the car's rear tires to spin up the engine's RPM. This can upset the braking/turn-in balance and can cause lose of car control.
Downshifted gearboxes usually respond well to throttle blipping, with or without double clutching. Mastery yields smoother transitions and longer synchro life.
Plus, it just sounds right!
Rick
[EDIT]File type conversion errors[/EDIT]
[This message has been edited by Rick Kean (edited 11-27-2001).]
Old Dec 31, 2001 | 03:07 AM
  #31
WTypeRogerX's Avatar
Default Re: Downshifting:heel/toe vs. rev matching....thoughts and comments (lotus)
I actually can't heel/toe, I have to toe/heel... heel on brake and toe on throttle...
My foot won't twist enough for my heel to touch the gas pedal..
I believe you are heel/toeing. Heel on brake first, and toe on throttle second.
Heel and toeing (a misnomer these days) I believe is actually done with ball of foot on brake then palm of foot (little toe side) on throttle.
The next day, after I posted my 1st time track experience and the need to learn to heel & toe instead of forcing the downshift, I tried literally hitting the brake with my heel and toeing the throttle. It's almost impossible that way since you have almost no pressure control with your heel. Next time I'll try using the ball of my foot on the brake instead.
Correct me if I am wrong, but this is what I believe to be the correct steps in heel & toeing:
Brake -> clutch down -> blip throttle -> downshift -> clutch up -> move foot from brake to throttle and accelerate
There was a site once-apon-a-time posted here that explained heel & toeing really well, including footprint pictures, but I never bookmarked it.
Anybody successful in heel & toeing stock pedals with size 8 1/2 shoes?
Old Dec 31, 2001 | 06:31 AM
  #32
Greyout's Avatar
Default Re: Downshifting:heel/toe vs. rev matching....thoughts and comments (CTypeRogerX)
I rev match, heel-toe, and double clutch every downshift daily driving. Its no big deal. Its easy, and makes driving a LOT smoother and easier. I don't see why people have difficulty with it IMHO
Old Dec 31, 2001 | 07:57 AM
  #33
MrBite's Avatar
http://www.turnfast.com has some good diagrams and articles (on everything actually). Someone posted a really good animated .gif a while back showing how it works too...
Old Dec 31, 2001 | 08:11 AM
  #34
IntegraT's Avatar
Default Re: Downshifting:heel/toe vs. rev matching....thoughts and comments (Ross)
BTW Lloyd - your quote rocks. canibus is so sick it's not even funny. My favorite:
My word is bond like james, ni&&@s think they hard but they weak like seven days. ,that n!&&@ Can-I-Bus is still in his prime.
Oh yeah and I practice Heel and Toe Every day.
Old Dec 31, 2001 | 08:17 AM
  #35
ENDYN's Avatar
The Old One
Default Re: Downshifting:heel/toe vs. rev matching....thoughts and comments (MrBite)
Double clutching was used on non-syncro transmissions for down shifting and up shifting according to my books. Once transmissions become syncronized, there was no need to pause in neutral and letting out the clutch (the double clutch.) There are two ways to heel and toe. One with the heel on the base of the accelerator pedal using the toes to brake, the other is to reverse the combination.
Old Jan 15, 2015 | 03:50 AM
  #36
Xian's Avatar
Spammer ^^^^.
Edit:
Spam post was deleted...
Old Jan 17, 2015 | 08:22 AM
  #37
94eg!'s Avatar
#1 Super Guy
Loved
rev-matching = reduced wear on the clutch (if done correctly)
double-clutch = reduced wear on the synchros (if done correctly)
heel-toe = the act of braking and rev-matching at the same time
BTW: If you have big feet, you can roll your foot to blip the throttle instead of actually turning it 45* to operate both pedals.
Old Jan 19, 2015 | 03:48 PM
  #38
underrated99si's Avatar
Im 6 foot 2 with a big *** foot. I dont do heel toe its more of big toe little toe with a ancle roll. Its the same thing I just can rotate my size 12's or leg to do heel toe. Wider Aftermarket pedals help with this method alot aswell as tighten up ur throttle cable to make blipping easier aswell
SPOOLINmatt
Jun 28, 2012 11:39 PM
[HrZn]4life
100
Mar 1, 2010 09:58 AM
fandirabbani08
Honda Civic (2006 - 2015)
Feb 16, 2007 12:47 PM
eknine
Jul 18, 2003 08:06 PM
