Do small things from spoon help?
Old May 26, 2002 | 09:37 AM
FroggyR's Avatar
Default Do small things from spoon help?
Ok guys, now do the Spoon B-series Thermostat help the R's ability to cool itself or is it the same as stock except it says spoon? What about the Spoon B-series Coolant sensor? I know that the magnetic oil drain plug helps out but what about the radiator cap? It's the same as stock except from spoon right?
Old May 26, 2002 | 09:40 AM
Flux's Avatar
Default Re: Do small things from spoon help? (FroggyR)
The radiator cap from Spoon is not the same as stock - it raises the pressure inside the cooling system and this raises the boiling point...
Old May 26, 2002 | 10:50 AM
Dr Pooface's Avatar
Default Re: Do small things from spoon help? (Flux)
You can buy a generic cap that does the same thing for way cheaper.
Old May 26, 2002 | 11:53 AM
len's Avatar
len
Default Re: Do small things from spoon help? (Ddub)
No way! Spoon radiator caps can hold more pressure because the sticker they put on top of it add to it's strength.
BTW, that drain plug can be purchased at your local autozone. Not worth the $$ in my opinion.
Old May 26, 2002 | 12:02 PM
JDM_DOHC_SiR's Avatar
New User
Do small things from Sp00n help?
Yep make your wallet lighter
Old May 26, 2002 | 12:19 PM
SwiftTypeR's Avatar
New User
Default Re: Do small things from spoon help? (JDM_DOHC_SiR)
what size drain plug?? will it fit a del sol too? ill buy em for both my cars.
civic_1
Sep 13, 2013 09:09 PM
IntegrasAreBest
Jan 12, 2009 07:36 AM
turbo eg2
Northern California (Sales)
13
Nov 8, 2005 08:59 PM
johnclaunch
Jul 22, 2004 06:55 PM
