Distributor Problems, Distributor King doesn't work?
Old Oct 27, 2005 | 10:15 AM
totsie7944's Avatar
Default Distributor Problems, Distributor King doesn't work?
I have order now 2... yes TWO distributor king dizzy's, and will have to return them both! ( AS an aside I would like to say they have been soo very nice to me in this process) But my stock Dizzy was making crackling noises and the R wouldn't redline without sputtering anymore, so I order a new dizzy.
Well upon install my Tach stopped working... I put the old one back on and the Tach worked fine... but after 2 King Dizzy's I know its got to be something with the OEM vs Dizzy King thats keeping my Tach from working... I am getting tuned soon so I would like to have my Tach working, even though I won't need it.....
I am not familiar with doing any work on distributors, but I guess I will have to take apart the OEM one and see if I can fix it.. Anyone have any ideas or advice?
Old Oct 27, 2005 | 10:29 AM
uNF$@#!'s Avatar
Default Re: Distributor Problems, Distributor King doesn't work? (totsie7944)
i've seen lanceh order up a distributor king distributor and throw it in his broke kaa to fix it
Old Oct 27, 2005 | 10:32 AM
uNF$@#!'s Avatar
Default Re: Distributor Problems, Distributor King doesn't work? (255.255.255.255)
chances are something else might be wrong unless its just dumb luck that both didnt work for you.
Old Oct 27, 2005 | 11:36 AM
BudMan's Avatar
I'm guessing it's something else wrong...is it the stock tach that stops working?
Are you sure there isn't a pin loose in the connection to the dizzy?
Have you tried any other solutions? Borrow a dizzy from someone else's R?
Jeff - who loooooooves dizzy king
Old Oct 27, 2005 | 11:47 AM
Opie's Avatar
<--Has a Dizzy King dizzy in #97. No problems yet
Old Oct 27, 2005 | 12:10 PM
Batoutahell's Avatar
I have a Dizzy King in my R and a Dizzy King in my crx. I had to send the crx dizzy back for a replacement because one of the pin-outs was not secure. It was a major PITA to diagnose why my engine was sputtering, and I replaced the entire engine harness before I determined that the dizzy wiring was defective.
Old Oct 27, 2005 | 12:17 PM
KayOs's Avatar
Try to re-tighten and smear some dialectic grease on your coil & ignitor connection (your OEM distributor)....see if that helps any.
Old Oct 27, 2005 | 12:20 PM
canuckr's Avatar
Default Re: (Opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opie &raquo;</TD></TR><TR><TD CLASS="quote">&lt;--Has a Dizzy King dizzy in #163. No problems yet </TD></TR></TABLE>
It sounds like there is something else wrong, other then your dizzy.
Old Oct 27, 2005 | 07:20 PM
totsie7944's Avatar
Default Re: (canuckr)
no its def the dizzy guys... Tach was working fine with the busted Dizzy till I put the new one on... If I PUT the OLD ONE back on, the tach works again... its weird..
However with the Dizzy King ones, when I start the car cold, the tach needle goes up for a split second then drops down to nothing.... Kinda weird.. I am soo lost haha
Old Oct 27, 2005 | 10:29 PM
strepto's Avatar
Default Re: (totsie7944)
I've sold around 20 Dizzy King distributors the past two years, and not once have I heard about anyone with this problem, or any other for that matter. I am not saying that it isnt true or not a genuine problem - but if you tried with two units - its more likely that you are using the wrong kind.
Old Oct 28, 2005 | 08:06 AM
function83's Avatar
Default Re: (strepto)
im not sure if your car is a 00-01.
i believe the tach signal is setup different between a obd2a to obd2b.
look into it, wiring diagrams perhaps.
Old Oct 28, 2005 | 02:59 PM
Rene M's Avatar
Default Re: (function83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by function83 &raquo;</TD></TR><TR><TD CLASS="quote">im not sure if your car is a 00-01.
look into it, wiring diagrams perhaps.</TD></TR></TABLE>
Old Oct 31, 2005 | 11:53 AM
totsie7944's Avatar
Its a 2000, but I have talked to the guy at Dizzy King like 4 times now and he has confirmed that I have the right one... Even though on the site it says the Dizzy is good for 00 AND 01... I don't know whats going on. I might try buying one from pep boys and see if it works...
Draven8795
Mar 11, 2012 02:49 PM
lluks_844
Oct 14, 2008 01:53 PM
totsie7944
Nov 3, 2005 06:52 PM
blacksheep
Oct 13, 2002 10:08 PM
