Cusco Zero 2 Coilver Setup
Old Jul 7, 2004 | 06:10 PM
JDM_Type-R's Avatar
Default Cusco Zero 2 Coilver Setup
Just wondering if anyone had any information on these set of coilovers because I might get a set at a good price. I think they are both height and damper adjustable, and spring rates are 9/5. anybody else know anything about these?
any info appreciated. thanks alot.
Old Jul 7, 2004 | 10:33 PM
Dr. EKology's Avatar
Default Re: Cusco Zero 2 Coilver Setup (JDM_Type-R)
Cusco stuff is awesome! The Zero-2's are valved very well and are extremely solid. If I could score a set for my EK I would ****** it up in no time.
I say jump on it!!
Old Jul 8, 2004 | 12:20 AM
JDM_Type-R's Avatar
Default Re: Cusco Zero 2 Coilver Setup (EKology)
anybody else? and any other info!?
Old Jul 8, 2004 | 06:29 AM
Stinkycheezmonky's Avatar
Suspetise...
What would you be using it for? Track days, just cruising around, the look, back roads, etc. A friend of mine has them on his 240SX and loves them, although the minimal lowering is already absurdly low (as in, the highest setting for his is like a 2 1/2" drop from stock). Not sure if it'd matter to you or not, but I think Cusco does not have any US shops, so if you needed them rebuilt or anything you'd have to ship it over to Japan.
Old Jul 8, 2004 | 10:52 AM
.RJ's Avatar
.RJ
Default Re: Cusco Zero 2 Coilver Setup (sscguy)
A friend of mine had the Zero-2<FONT COLOR="red">R</FONT> on his WRsuX. They were stiff, but they felt much better than 475/600# springs on Koni yellows on my 91. I think the spring rates were in the 300-350# range, so the wheel rates between the two cars is pretty similar. Felt about the same in stiffness, but just... better controlled.
Old Jul 8, 2004 | 02:40 PM
JDM_Type-R's Avatar
Default Re: Cusco Zero 2 Coilver Setup (.RJ)
in terms of stiffness, do you guys think they are too stiff for the street? what would they compare to? zeal b6's? and anyone know what the minimum drop it has on the dc2r? thanks alot.
Old Jul 8, 2004 | 02:56 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Type-R &raquo;</TD></TR><TR><TD CLASS="quote">in terms of stiffness, do you guys think they are too stiff for the street? </TD></TR></TABLE>
If you are a puss, yes (no offense, just being realistic).
They're certainly tolerable if the roads are good.
Old Jul 8, 2004 | 10:39 PM
They should be very streetable at the lower settings.
Old Jul 14, 2004 | 11:01 AM
b18c1eg
Guest
Posts: n/a
Spring rates are as follows:
9K on the front
6K on the rear
As far as being super low, when I put mine on my ITR is was slightly lower than OEM, then I decided to lower it much more. IMO they have a great range of height, I never had any issues.
Nukabe Automotive is the Master Import Distributor for Cusco Japan and has been bringing them over for about 1 1/2 year.
http://www.napsusa.com
Feel free to give us a call. Also, go to http://www.cuscoracing.com (english website owned by Cusco) and you will see our name in the distributor link.
Thanks,
Brad
brad.himes@napsusa.com
Swipe'd
Nov 17, 2007 06:26 PM
evolvedAP1
Jul 8, 2006 06:29 PM
91tealhatch
Suspension & Brakes
Mar 21, 2006 01:53 PM
yoshi234
Sep 26, 2002 02:41 PM
t
Jan 22, 2002 11:06 PM
