ctr pistons
Old Jul 31, 2003 | 08:50 PM
R3dL1n3's Avatar
Default ctr pistons
Im planning to use ctr pistons with jun3s.
Was just wondering if these pistons can handle revs over 9000?
will it be safe?
and also should i get a spoon headgasket or just use the stock one?
Old Jul 31, 2003 | 08:59 PM
MiraiZ's Avatar
Default Re: ctr pistons (R3dL1n3)
properly tune...9000 should be ok...
Old Jul 31, 2003 | 10:48 PM
R3dL1n3's Avatar
Default Re: ctr pistons (MiraiZ)
but not over 9000? i plan to take ge tit to 9500??
Old Aug 1, 2003 | 12:14 AM
green_GSR's Avatar
I'll be more worried about your valvetrain than anything else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R3dL1n3 &raquo;</TD></TR><TR><TD CLASS="quote">but not over 9000? i plan to take ge tit to 9500??
Old Aug 1, 2003 | 12:38 AM
KTeller8's Avatar
yes, pick up some ef-1 springs, valves and retainers: They will handle way over 9k and are guarenteed that not to break, when used together
Old Aug 1, 2003 | 12:44 AM
R3dL1n3's Avatar
Default Re: (KTeller8)
I have jun valvetrain already(valve springs and retainers)
so they will rev to 9500 redline np?
thanks
Old Aug 1, 2003 | 06:20 AM
sgT's Avatar
sgT
Default Re: (R3dL1n3)
built properly the pistons are fine.
ditch thevalvesprings though.
Old Aug 1, 2003 | 06:26 AM
canuck-mx6's Avatar
Default Re: (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">built properly the pistons are fine.
ditch thevalvesprings though.</TD></TR></TABLE>
I use the jun valvesprings and have not had a problem yet &lt;knock on wood&gt;
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">but not over 9000? i plan to take ge tit to 9500??</TD></TR></TABLE>
Why do you want to rev that high, are you sure that you will still be making power there?
RTW DC2R's Avatar
yes they are fine. worry more about your valve train if you plan to rev that high.
side note, dont try to set a goal to rev to 9500 just so you can say you can rev that high. build you motor and set your rev limit where you motor stops making power(youll know by looking at your dyno charts). no point in revving to 10K and risking damage to the motor if your motor only makes power to 8500. catch my drift?
Old Aug 1, 2003 | 06:58 AM
R3dL1n3's Avatar
Default Re: (RTW DC2)
yes np i know wat u guys mean i was just wondering cos a friend told me ctr pistons cannot handle revs past 9000. and i have "read"(not experienced) that jun3s make power past 9000+
thanks for ur help i will try to get toda or crower valve springs if i can.....
Old Aug 1, 2003 | 07:05 AM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R3dL1n3 &raquo;</TD></TR><TR><TD CLASS="quote">yes np i know wat u guys mean i was just wondering cos a friend told me ctr pistons cannot handle revs past 9000. and i have "read"(not experienced) that jun3s make power past 9000+
thanks for ur help i will try to get toda or crower valve springs if i can.....</TD></TR></TABLE>
I would avoid crower if I were you. Im currently running crower but have heard too many horror stories so Im gonna switch to something else soon.
Old Aug 1, 2003 | 07:09 AM
Tweakmeister's Avatar
get ef-1 valvesprings.
http://www.ef-1.com
Old Aug 1, 2003 | 07:38 AM
Cheap Bastard's Avatar
New User
Default Re: (sgT)
what's wrong with the valve springs? i have mine for over 80k miles.
Old Aug 1, 2003 | 08:12 AM
Spoond TEG's Avatar
Default Re: (Cheap Bastard)
I would worry about Piston to valve contact.
Old Aug 1, 2003 | 08:46 AM
STOLEN - ITR 98-0652's Avatar
Default Re: (Spoond TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoond TEG &raquo;</TD></TR><TR><TD CLASS="quote">I would worry about Piston to valve contact.</TD></TR></TABLE>
Clay the CCs, eh?
Old Aug 1, 2003 | 08:47 AM
RTW DC2R's Avatar
shouldnt be a problem unless the head or block was seriously milled...mine is NOT a problem.
Old Aug 1, 2003 | 07:59 PM
R3dL1n3's Avatar
Default Re: (sgT)
Steve what do you mean by built properly??
hytec
Apr 13, 2006 12:57 PM
sublimnal
Jun 10, 2004 11:20 AM
blackspoonem
Jan 12, 2004 09:18 PM
B16Hatchcx
Dec 30, 2003 11:16 AM
lsvtec0394
Aug 6, 2003 01:30 PM
