CTR piston question
Old Jun 22, 2003 | 08:34 PM
SpeedRacer00-667's Avatar
Default CTR piston question
ok, i finally pulled off my head. i had 5k of boost and #3 piston is cracked. i want to go back to N/A, can i put CTR pistons in my R motor w/ out any problems?
i did a search ,but i need a little more info on it
thanks
basically i want to have ctr pistons w/ a stock R head, stock head gasket, pretty much the whole motor will be stock w/ the exception of CTR pistons.
Old Jun 22, 2003 | 08:38 PM
Big Teggie's Avatar
Default Re: CTR piston question (SpeedRacer00-667)
Why do you wanna go back to NA?
You should have no problems with CTR's
Old Jun 22, 2003 | 08:42 PM
JaeOne3345's Avatar
check the surface of the cylinder walls. dont want any bad scratches and scarring so if you have these go ahead and do a .25 OS bore. as long as everything else checks out okay id say it be perfectly fine. how many miles on the car? if willing to spend extra cash id say a fresh bottom build would be perfect (bearings, etc etc) simply for piece of mind. ask someone wise with engine building like sgT, cheetah, etc etc you get the point. to be sure. they can help more then i can but i tried
Old Jun 22, 2003 | 08:44 PM
Default Re: CTR piston question (JaeOne3345)
the walls are in good shape, the bottom end has 32k the head has about 10k on it
thanks for the info.
Old Jun 22, 2003 | 08:53 PM
JaeOne3345's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedRacer00-667 &raquo;</TD></TR><TR><TD CLASS="quote">the walls are in good shape, the bottom end has 32k the head has about 10k on it
thanks for the info.</TD></TR></TABLE>
you should be good to go then gladi could help.
just have your local (qualified ) machinist get a nice crosshatch on the walls for you (hone) for the fresh rings to be able to seat. some people still opt for the .25 OS over bore. (technically it IS more displacement right? hehe)
Old Jun 22, 2003 | 08:59 PM
H-PIMP's Avatar
Did you do a full repaint of your FBP ITR to CW?
Old Jun 22, 2003 | 09:52 PM
Default Re: CTR piston question (H-PIMP)
yeah, everything but the engine bay. u know how bad i wanted a cw one.
Old Jun 25, 2003 | 06:32 PM
ONe more quetion. what is the bore and CR of the ctr pistons? is there a difference between US and JDM?
thanks
Old Jun 25, 2003 | 06:38 PM
jonas's Avatar
there is only a JDM CTR piston, no such thing as a USDM CTR piston. its 81mm.. or you can get it in .25 OS just like any other b-series piston (except b20).
CTR pistons in an ITR = about 12.1:1 - 12.2:1
Old Jun 25, 2003 | 06:41 PM
IN VTEC's Avatar
CTR (PCT) pistons are JDM-only pistons.
You have the option of standard bore (81mm) or factory-specified overbore (81.25mm).
To use the over-sized pistons, you need to have the cylinder bores bored/honed or honed out ten-thousandths on an inch (.010" = .25mm).
You should have the pistons weight matched, but it shouldn't be necessary to touch the rest of the rotating assy for a rebalance b/c of the slightly larger/heavier pistons.
Old Jun 25, 2003 | 06:52 PM
len's Avatar
len
Default Re: (jonas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonas &raquo;</TD></TR><TR><TD CLASS="quote">CTR pistons in an ITR = about 12.1:1 - 12.2:1</TD></TR></TABLE>
CTR pistons in an ITR + 1 Layer Headgasket + milled head = 18.1:1...LoL...Yeah right...
CTR pistons should work fine. If you do plan to run thinner headgasket and mill the head, I suggest claying your motor just to be on the safe side. If you're going to run cams later, you'll have to clay it depending on which one you go with.
Old Jun 25, 2003 | 06:58 PM
euclid's Avatar
Default Re: CTR piston question (IN VTEC)
the pct will be around 12.1:1 in a b18 block
Old Jun 26, 2003 | 10:52 AM
Default Re: CTR piston question (euclid)
thanks, i'll let u know how it turns out
Bowe Blanyer
Dec 22, 2014 08:34 AM
EgSalad
14
Sep 26, 2006 11:06 AM
itr1244
Jun 6, 2006 11:42 AM
Teepo
Nov 7, 2002 08:28 PM
Rydaddy
Oct 24, 2002 10:34 AM
