coolant flush question
Old Nov 24, 2002 | 01:59 PM
kkim's Avatar
Default coolant flush question
I know to remove the radiator and engine drain plugs, but what are the steps to flush all the old coolant out of the system once the coolant is drained and before I fill with the new stuff?
is sticking a garden hose into the radiator using fresh running tap water okay while running the engine sufficient or should I just forget about it and drain and fill without trying to flush all the old coolant out?
Helms makes no mention of how to flush the coolant system.
thanks
Old Nov 24, 2002 | 02:02 PM
uNF$@#!'s Avatar
Default Re: coolant flush question (kkim)
uhm. undo plug on radiator, and bolt on engine block. let it all drain out.
then hondabond the bolt back on, plug up the radiator and j00 are ready to go!
Mr. Plow Mr. Plow ...
edit: (dont run the engine without coolant...thats just idea)
[Modified by Soup ****, 6:04 PM 11/24/2002]
Old Nov 24, 2002 | 02:15 PM
kkim's Avatar
Default Re: coolant flush question (Soup ****)
just leave the old stuff that doesn't drain out?
just making sure cause when I did the coolant system on my 325 bmws, part of the procedure was to run tap water through the cooling sysytem while the engine was idling to flush out the system. when I did that, I found a lot of crud would come out with the flushing.
maybe the honda cooling system design is just different and not needed?
and while I agree with you that running an engine with no coolant is bad, if I were to have fresh tap water running through the system while it was idling, how could that harm the engine? not arguing, just curious.
[Modified by kkim, 12:16 PM 11/24/2002]
Old Nov 24, 2002 | 05:42 PM
Batoutahell's Avatar
I believe Helms says you can place your garden hose on top of the radiator and power-blast the system to flush it out.
Old Nov 24, 2002 | 05:53 PM
kkim's Avatar
Default Re: coolant flush question (Batoutahell)
are you serious? if so, where in the helms does it say that? I just looked through mine and couldn't find anything like that. if you aren't serious...
anyway, already changed my coolant, but to flush it, I just put the engine plug and tightened the radiator drain plug, filled the system back up with fresh water and pulled the engine block plug off to let the water drain back outafter the radiator started overflowing. did this 3 times and the water was coming out clear by then from the block plug. opened the radiator drain plug to let all of the water out of the system, then tighened everything back up and filled with Honda coolant type 2.
job done.
Old Nov 24, 2002 | 06:11 PM
Oops, my bad. It's Haynes, not Helms, that encourages use of a garden hose. It worked fine for me.
Old Nov 24, 2002 | 06:15 PM
kkim's Avatar
okay, thanks for your input... much appreciated.
Old Nov 24, 2002 | 08:23 PM
Bbasso's Avatar
Use the hose It will help. Don't be worried.
Old Nov 24, 2002 | 08:49 PM
ITR#132's Avatar
Default Re: coolant flush question (Bbasso)
By the radiator flush from autoparts store and follow the directions on the back of the bottle.
Old Nov 25, 2002 | 09:17 AM
andrewasf77's Avatar
Default Re: coolant flush question (ITR#132)
where is the drain plug on the engine, i cant find it
Old Nov 25, 2002 | 11:24 AM
Default Re: coolant flush question (andrewasf77)
The huge bolt on the front of the block, kind of behind the clutch slave.
Old Apr 23, 2003 | 08:48 AM
ragejed's Avatar
that drain plug...there a washer that i need to replace on it? like a crush one?I got liquid tefon that is ment for this, can I use it?
Old Apr 23, 2003 | 09:22 AM
Dirt's Avatar
Default Re: coolant flush question (ragejed)
What about pressurizing the system when flushed/drained so theres no air in the system?
Old Apr 23, 2003 | 09:24 AM
CPR's Avatar
CPR
The directions for the coolant flush should be in the Cooling section of the Helms. I just read through it last night.
Old Apr 23, 2003 | 09:43 AM
ragejed's Avatar
Default Re: coolant flush question (CPR)
Ya...i got the helms. I would like some first hand advice, as I dont like the helms directions. As for filling it..
Do I leave the cap off and motor running when I fill it?
Old Apr 23, 2003 | 12:07 PM
fiebru1119's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">that drain plug...there a washer that i need to replace on it? like a crush one?I got liquid tefon that is ment for this, can I use it?</TD></TR></TABLE>
Yes you should replace it as it is a crush washer. However, make sure you call around because the dealers dont usually carry 24mm (i think) washers in stock. I had to reuse mine.. 6K miles and no leaks :knock on wood:
Old Apr 23, 2003 | 12:08 PM
fiebru1119's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">Ya...i got the helms. I would like some first hand advice, as I dont like the helms directions. As for filling it..
Do I leave the cap off and motor running when I fill it? </TD></TR></TABLE>
Put the cap on and turn in untill it stops the first time (you will know) then run the car until the cooling fans come one at least twice. Remove the cap, and top off the cooland and the resevoir.
Old Apr 23, 2003 | 01:44 PM
ragejed's Avatar
Default Re: coolant flush question (fiebru1119)
Guys..i ran the car idle...Ever since i rebuilt it, new gasket, intake manifold was off. type r oil cooler, etc. Messin around back there...i havent seen the fans come on yet.
Fuse is fine, i checked. There a way to force the fan on? or someway i can check it? Fan switch IS plugged in, already checked. car is NOT over heating either. Its actually running a tinny bit cooler then it did before
Old Apr 23, 2003 | 02:03 PM
Aaron M's Avatar
when i did mine, i let the car idle for like 10 mins, the fans never came on....
Old Apr 23, 2003 | 02:18 PM
ragejed's Avatar
Default Re: coolant flush question (SilverB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">when i did mine, i let the car idle for like 10 mins, the fans never came on....</TD></TR></TABLE>
I feel better
keep in mind..its cold out today up here brrrrrrrrrrr
Old Apr 23, 2003 | 02:30 PM
Fuuma0083's Avatar
you can goto Autozone, Pep Boys, etc.... and get yourself a kit to place a bucket that connects to the radiator (from the cap) that holds coolant and you just fill it up and wait for it to run through and as it goes down just keep filling it.
whiteGSR
Jul 26, 2022 03:06 PM
aznromeo4u
Feb 13, 2015 07:04 AM
MrViet
Oct 20, 2009 09:43 PM
return_2020
14
Oct 19, 2005 09:23 PM
Etylorcen
Aug 15, 2002 01:24 PM
