Comptech Ice box question
Old Mar 2, 2002 | 06:51 PM
hooptie157's Avatar
Default Comptech Ice box question
should I get the comptech short ram to the ice box for 329.89 or just the ice box with a drop in filter???
What are the advantages and disadvantages of both and I have no problem spending the 329.00 for both. (is it even worth it?)
Old Mar 2, 2002 | 06:58 PM
1GreyTeg's Avatar
Default Re: Comptech Ice box question (hooptie157)
Get just the Box with their Foam filter.
The short ram produced negligable results for me. I just keep it now for a slightly nicer look and cause resale is minimal. I did run it with the stock piping and again with their pipe for comparison. I noted a slight if any quicker throttle response as the biggest difference. The cost of the pipe is not worth it in my books.
IMHO of course
A.
Old Mar 2, 2002 | 07:13 PM
onyx00's Avatar
Default Re: Comptech Ice box question (1GreyTeg)
I'll second that.
Old Mar 2, 2002 | 07:16 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Comptech Ice box question (onyx00)
I'll third that.
Old Mar 2, 2002 | 08:57 PM
uber_nihilist's Avatar
I 'd 4th that, (just icebox) if you only worry about performance, but if you're into the lowriding and show scene I would definitly get the polished intake.
I have both the short ram and icebox. An advantage of the polished aluminium intake is that it reflects heat well. The stock one doesn't, because it ain't polished. Nuff said.
Old Mar 4, 2002 | 09:34 AM
yakkosmurf's Avatar
Default Re: Comptech Ice box question (natadekoko)
I got the Comptech intake with my Icebox. I got a good deal, and I liked the way it looked. It's probably not worth the retail cost.
Old Mar 4, 2002 | 09:37 AM
MPH's Avatar
MPH
New User
You don't need the short ram. Just the icebox.
Old Mar 4, 2002 | 09:40 AM
hooptie157's Avatar
Default Re: Comptech Ice box question (MPH)
Thanks I ordered the comptech ice box with the drop in filter
Petah's Avatar
Anyone got pic of the Comptech Ice Box?
Old Mar 4, 2002 | 09:54 AM
Xian's Avatar
Default Re: Comptech Ice box question (eg-six)
Comptech's website does...
Old Mar 4, 2002 | 09:59 AM
Comtechgsr2000s's Avatar
New User
Default Re: Comptech Ice box question (Xian)
Just get the icebox and the foam filter.
Old Mar 4, 2002 | 10:02 AM
TypeR0149's Avatar
Default Re: Comptech Ice box question (Mugenblkgsr2000)
i will 7th that
Old Mar 4, 2002 | 06:52 PM
6ghatch's Avatar
here's mine
Old Mar 4, 2002 | 07:01 PM
xtrafastcivic's Avatar
Default Re: Comptech Ice box question (6ghatch)
6ghatch
what else do you have in that b16a?
Old Mar 4, 2002 | 07:06 PM
6ghatch's Avatar
Default Re: Comptech Ice box question (XtraFastCRX)
6ghatch
Comptech Icebox, Skunk 2 stage 1 cams, gears, intake manifold, valve springs, ti retainers, CTR N1 crank pulley, JDM ITR header, Godspeed test pipe, fireball exhaust, Skunk 2 P28ecu, Fields VTEC controller. Dyno results comming soon!
[Modified by 6ghatch, 4:08 AM 3/5/2002]
Old Mar 4, 2002 | 07:37 PM
tampaSi's Avatar
New User
So comptech is basically BS'ing when they say you have to use their intake pipe?
Would i have to use the pipe on my Si or will the icebox & filter setup work the same way as well?
Old Mar 4, 2002 | 07:41 PM
6ghatch's Avatar
Default Re: Comptech Ice box question (tampaSi)
I used a ITR intake hose, the Civic SI hose is too small and not the right length. If you are putting the setup in a 6th gen Civic, just get the Icebox for the 99-00 Civic SI and the ITR Drop in filter upgrade, then purchase a ITR intake tube. If you are still running OBD2, you will need to make a hole in the tube for the sensor.
Old Mar 4, 2002 | 07:42 PM
ntt's Avatar
ntt
In partial defence of Comptech: I emailed them and asked if I needed the pipe and they said No. Also, on their message boards they have said No on this issue.
Inconsistent? Yes.
ntt
Old Mar 4, 2002 | 08:02 PM
tampaSi's Avatar
New User
Default Re: Comptech Ice box question (ntt)
Thanks for the info guys
SPOONfdEK
Aug 15, 2003 10:16 AM
LillDragun
Sep 2, 2002 10:15 PM
JLange
Aug 31, 2002 03:17 AM
eargrub
Mar 21, 2002 07:05 PM
magic hat #9
Jan 25, 2002 07:21 AM
