Comptech Header question?
Old Dec 19, 2002 | 08:49 AM
OBDI JEDI's Avatar
Default Comptech Header question?
On comptechs website they have a TIG and a MIG welded header....
there is a price difference but is there a performance difference?
sorry if this question has been repeated but i did a search and nothing came up.
Thanxs in advance!
Old Dec 19, 2002 | 09:03 AM
Big Phat R's Avatar
Default Re: Comptech Header question? (OBDI JEDI)
What is MIG Welding?
MIG stands for Metal Inert Gas welding, many times called Wire-feed.. Also referred as GMAW (Gas Metal Arc Welding). The "Metal" refers to the wire which is what is used to start the arc. It is shielded by inert gas and the feeding wire also acts as the filler rod. A semi-automatic process, it is fairly easy to learn and use.
What is TIG Welding?
TIG stands for Tungsten Inert Gas welding. Also called GTAW (Gas Tungsten Arc Welding) and Heliarc® which was Linde's trade name for the TIG process when it was introduced many years ago. The arc is started with a tungsten electrode shielded by inert gas and filler rod is fed into the weld puddle separately. A slower process than MIG, it produces a more precise weld and can be used at lower amperages for thinner metal and can be used on exotic metals. TIG does require quite a bit more time than MIG to learn. It is similar in technique to gas welding.
Summary: TIG is better than MIG.
Old Dec 19, 2002 | 09:07 AM
n1ek's Avatar
Default Re: Comptech Header question? (Big Phat R)
so since it takes them more time to make the tig header....and time=money.
it cost an extra hundred bucks.
both have their warranty though, and both are street legal.
Old Dec 19, 2002 | 09:14 AM
OBDI JEDI's Avatar
thank you for explaining the difference.... so basically no performance gain just quality?
Old Dec 19, 2002 | 09:20 AM
vtec.dc2's Avatar
not even quality, the looks in my opinion.. welder defines quality
Old Dec 19, 2002 | 09:26 AM
n1ek's Avatar
Default Re: Comptech Header question? (vtec.dc2)
its quality also. hte welder plays a large part in quality if the welds...but so does the type of weld used.
the tig is also polished stainless while the mig is burmished stainless.
Old Dec 19, 2002 | 09:40 AM
Q-OnE's Avatar
Default Re: Comptech Header question? (n1ek)
wow...thats some good info someones been taking their basic metal 101 i see.
Old Dec 19, 2002 | 10:17 AM
OBDI JEDI's Avatar
are there any performance differences between the GSR and the ITR model?
Old Dec 19, 2002 | 10:34 AM
vtec.dc2's Avatar
fitment, gsr exhaust/cat is different lenght
Old Dec 19, 2002 | 10:36 AM
vtec.dc2's Avatar
so how is that quality, other than cosmetic? i sure would choose tig over mig if option offered, but only cause it looks bling bling.
[Modified by vtec.dc2, 3:51 PM 12/19/2002]
Old Dec 19, 2002 | 10:42 AM
Chris N's Avatar
performance from a weld???
TIG is stronger AND nicer to look at.
Old Dec 19, 2002 | 11:43 AM
n1ek's Avatar
Default Re: Comptech Header question? (Chris N)
TIG results in a smaller weld bead but takes a very good welder. it takes appro 30% longer to do than a mig weld. TIG welds are used in aerospace, indycar and other sportscar welds. it is the strongest weld available and also the cleanest when done correctly.
juiced2ndgenteg
Welding / Fabrication
Jan 31, 2010 04:20 AM
Flashmn
Dec 26, 2006 07:29 AM
SolBreak
Feb 9, 2005 12:26 PM
VsR785
Mar 6, 2004 08:43 PM
