compression test results
Old Dec 15, 2001 | 06:51 AM
RJL's Avatar
RJL
New User
Default compression test results
220psi all across the board
250 psi with a little oil added across the board.
I am losing oil and trying to find the problem.
These numbers seem kinda low to me. Pistons are new and were installed 1 1/2 weeks ago. CTR Pistons with JUN III cams. Any info would help
[Modified by Badboy01GSR, 3:52 PM 12/15/2001]
Old Dec 15, 2001 | 07:04 AM
RJL's Avatar
RJL
New User
Default Re: compression test results (Badboy01GSR)
any insight would help. Im thinking the valve seals are shot
Old Dec 15, 2001 | 07:17 AM
FAST94GSR's Avatar
New User
have you given enough time to let those new rings seat? drive it a few hundred miles.
Old Dec 15, 2001 | 07:20 AM
RJL's Avatar
RJL
New User
Default Re: compression test results (FAST94GSR)
well its been 1200 miles. Ive heard of some cars not seating until way past 2500 miles on a rebuild. At least i know my car is consistant 220 psi across, which believes me to think that its not the rings but my valve seals are still the same seals that were in mt car before, and they take alot of abuse
Old Dec 15, 2001 | 07:24 AM
FAST94GSR's Avatar
New User
I have a little more mileage on mine. if you are consistent yea it sounds like something else. might be the seals, i'm doing a leakdown test today, I'm almost 99% positive its the seals.
A way to know for sure is when you start the car up are you getting smoke?
Old Dec 15, 2001 | 07:27 AM
FAST94GSR's Avatar
New User
wait a minute you put 1200 miles on , in one and a half weeks? I think its better to do 1200 miles of stop and go driving than 1200 miles freeway driving for breaking in the rings. did you rehone the cylinders?
Old Dec 15, 2001 | 07:28 AM
RJL's Avatar
RJL
New User
no just consensation smoke white, but when it reached normal temperature its fine.
Im probably just paranoid and switched to sythetic to soon. Im not leaking oild, just want to know where the hell its going. Im also thinking the valve seals are shot
Old Dec 15, 2001 | 07:30 AM
RJL's Avatar
RJL
New User
yeah rehoned everything. I do 100 plus highway miles a day
Old Dec 15, 2001 | 07:31 AM
FAST94GSR's Avatar
New User
there's your problem you are using synthetic. you are probably getting blowby.
you are supposed to use reg motor oil to help seat the rings. the synthetic is too light.
Old Dec 15, 2001 | 07:53 AM
sgT's Avatar
sgT
220 is kinda low. It should be at least 280 or higher.
The rings usually seat rather quickly, i'd say within a few hundred miles.
I doubt its the oil, but easy way to test is to go back to regular.
Old Dec 15, 2001 | 09:33 AM
RJL's Avatar
RJL
New User
Default Re: compression test results (sgT)
well heres an update i changed the oil, switched back to regular from synthetic and gained 30 psi in three cylinders and 35 psi in cylinder #1. So im at 255, 250, 250, 250. Hopefully the rings will get stronger and psi goes up (if that makes sense) Its a gsr btw). If not ill re ring the piston.
GTEater
Sep 30, 2010 09:43 PM
Integra_chick95
Aug 11, 2005 12:00 PM
Tony_EM1
May 26, 2005 10:34 PM
NVMYSi
Jun 24, 2003 09:51 AM
GsrSdn
Sep 22, 2002 04:23 PM
