Compression Test Result
Old Feb 16, 2002 | 03:44 PM
Liquidx02's Avatar
Default Compression Test Result
For those members who care here is my compression test result on my motor
Cyl#1=300psi Cyl#2=300 psi Cyl#3=300 psi Cyl#4=300psi (they are all at 300 because the compression tester only goes up to 300 psi. It kept bouncing off the needle.
B18c1 block
CTR pistons
PR3 head, mild port and polish
JUN III Cams JUN Valvesprings and Crower Titanium Retainers
ITR Intake Manifold w/ITR Throttle Body
Old Feb 16, 2002 | 04:46 PM
Liquidx02's Avatar
Default Re: Compression Test Result (Rattlesn8ke)
If my compression is that high, should i get a block guard. Im running on 94 octane and 100 is availble also. Should I advance my timing to 18 degrees BTDC?
Old Feb 16, 2002 | 05:08 PM
Liquidx02's Avatar
Default Re: Compression Test Result (redteggy)
mo detonation. im running at 47psi with the line on. im trying to get it tuned soon.
Old Feb 16, 2002 | 07:19 PM
Liquidx02's Avatar
loads of power at vtec
Old Feb 17, 2002 | 12:15 PM
Liquidx02's Avatar
is advancing to 18 degrees BTDC to risky??
jvtec95
Apr 16, 2007 06:26 PM
greasemonkeys
Jun 21, 2005 09:19 PM
pootie.teng
Jun 2, 2005 10:32 PM
jmcclell
14
May 2, 2004 07:15 PM
fastludeh22
Apr 28, 2004 07:06 AM
