Compression test and failed ignition coil
Old Jan 7, 2006 | 09:38 PM
andyt's Avatar
Default Compression test and failed ignition coil
If your ignition coil failed while doing a compression test, would you think it was a coincidence?
Also, I bought a coil for I think an Accord, and it looks exactly the same, in every detail except the writing and coloration, including weight, so is safe to assume it is equivalent?
Old Jan 7, 2006 | 10:04 PM
andyt's Avatar
Default Re: Compression test and failed ignition coil (neo_)
Well, as it happened, I had actually just pulled all the spark plugs out to look at them, so all the plug wires were already out of the way, and then the compression test was suggested, and then performed. So, no, I did not pull any fuses.
What do you mean it isn't being discharged?
Old Jan 7, 2006 | 10:39 PM
JDMH22HATCH's Avatar
Default Re: Compression test and failed ignition coil (andyt)
For future reference, you should unplug your distributor and main relay before you perform a compression test. But any b,d,h, or f series obd1 up internal igniton coil will work as a replacement
EKJOE
Jul 14, 2010 06:31 AM
KayTran
May 12, 2008 09:59 PM
tpr
Sep 13, 2005 09:00 AM
pootie.teng
May 27, 2005 08:56 PM
spettinger
Dec 4, 2002 11:19 PM
