compression ratio math
Old Oct 23, 2001 | 08:51 AM
MackSpeed-616's Avatar
Default compression ratio math
ok.. i always get this mixed up... if i use a piston made for a GSR motor netting a 12.3:1 compression ratio.... this would make for a 12.0:1 when used in a Type-R motor correct?
thanks!
Old Oct 23, 2001 | 09:36 AM
D's Avatar
D
Default Re: compression ratio math (TurboR616)
cr = max cylinder volume / min cylinder volume = (Vd + Vc) / Vc
Vd = displaced volume (ie, bore x stroke)
Vc = clearance volume (ie, everything left... space from head gasket, combustion chamber)
cc both pistons and figure it out for us. anyone ever cc'd both heads?
D
Old Oct 23, 2001 | 09:44 AM
ZygSpeed's Avatar
Default Re: compression ratio math (D)
Here we have the two extremes!!! hahahahaha.....
Even though he said "math" D, TurboR616 was just looking for a yes or no answer (but then we all knew that, right)!
The B18C1 motor' head is listed as CC'ing @ 41.6 (cc)
From what I remember reading the C5 head might be as much as 5 cc more.
But as far as the original question, YES ... the compression would be lower in the Type R motor due to the increased combustion chamber volume.
[Modified by zygspeed, 2:00 PM 10/23/2001]
hatch22ajdm
Engine Machining & Assembly
Jun 1, 2018 03:33 AM
ITR_1211
Jan 18, 2004 08:09 AM
