Compression Problem
Old Oct 16, 2008 | 11:34 AM
justinsane's Avatar
Default Compression Problem
My Setup:
2000 Integra GS-R
B18C1
ITR P73 Pistons 10.6:1
ITR Valve Springs on Exhaust Side
Stock Dual Valve Springs on Intake
ITR 00-01 Camshafts
Otherwise stock bottom end
slightly milled head
My questions are: i did a compression test and my numbers were : 205(4) 185(3) 195(2) 200(1)
Why is my compression so low? I know this is not as important as consistent numbers across the board, but I think my lower numbers are due to my cam gear timing of -2/+2 for intake/exhaust. Maybe reversion through the intake side? Other than leakdown testing, are there any other methods of maybe detecting a bent valve? The motor only has about 15k on it. That 185 worries me.
Old Oct 16, 2008 | 11:38 AM
walker111's Avatar
Default Re: Compression Problem (justinsane)
The reason is the guage itself. Be more worried about the consistency then the high of the number.
Old Oct 16, 2008 | 05:09 PM
WheaMyRyceGo's Avatar
Default Re: Compression Problem (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">The reason is the guage itself. Be more worried about the consistency then the high of the number.</TD></TR></TABLE>
Id be more worried about the numbers not being consistent. I've ran 205 across on one gauge to 225 on another, they dont really matter.
Old Oct 17, 2008 | 11:28 PM
justinsane's Avatar
Default Re: Compression Problem (WheaMyRyceGo)
bumpage
I know consistency is the key. Any ideas on detecting leaky valves other than leakdown?
Old Oct 17, 2008 | 11:35 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinsane &raquo;</TD></TR><TR><TD CLASS="quote">bumpage
Old Oct 18, 2008 | 10:17 PM
Bbasso's Avatar
Default Re: Compression Problem (Bbasso)
Another thread that was reported and nothing has been done...
Old Oct 19, 2008 | 01:23 PM
sander's Avatar
2.7(p/t)
Compression tests are extremely over rated. Do a hot leak down, and your question will be answered in a manner that does not consist of people guessing online.
BUT, if you want a really un reliable quick stupid test, you may do the following.
If you have a bent valve, it will show up on a valve lash check. The bent valve will consequently have more lash than a "good" cylinder. But again, this method sucks, and should not be used. Do a leak down and you'll know.
crazydominicanman
12
Sep 7, 2011 10:08 AM
Rocket
119
Oct 1, 2010 06:08 AM
EJ1B18c
Aug 26, 2009 02:50 AM
soon2bdropped
Mar 2, 2009 03:31 PM
SwiftTypeR
May 10, 2005 05:22 PM
