Coilover help
Old Aug 22, 2008 | 11:00 AM
itrjon's Avatar
Default Coilover help
What kind of coilover should I get now? I have a 98 itr with the first generation Apex WS. I am wanting to get something semi-aggressive yet daily drivable. I've seen some good write ups on PIC performance and the usual Tein set up. lmk what you guys are running and what your guys would recommend. Thanks
Old Aug 22, 2008 | 11:10 AM
The Dude's Avatar
Banned
Default Re: Coilover help (itrjon)
Stock ITR shocks and springs.
Old Aug 22, 2008 | 11:12 AM
touchmyHONDA's Avatar
tein mono flex... Ive daily-ed this setup for over a year in Chicago weather and roads.... still amazing
Old Aug 22, 2008 | 11:22 AM
jgirard's Avatar
Default Re: (touchmyHONDA)
I'm on JIC Magics, but I will be switching to PIC's The JIC's are fine but they aren't aggressive enough since they are 10k front 7k back
Old Aug 22, 2008 | 12:02 PM
citrus3000psi's Avatar
All depends on the cars purpose. If you road race/auto x then N1's, PIC is the way to go. If you just want to get low then just do a ground control/koni yellow build.
Old Aug 22, 2008 | 12:23 PM
KetteringITR's Avatar
Default Re: Coilover help (citrus3000psi)
Omni Power is what im getting if/when i get rid of the Apexi N1 99 Specs.
PS. there are probably 3098758 topics on this if you search. Youll find reviews and thoughts there.
Old Aug 22, 2008 | 12:58 PM
Default Re: Coilover help (KetteringITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KetteringITR &raquo;</TD></TR><TR><TD CLASS="quote">Omni Power is what im getting if/when i get rid of the Apexi N1 99 Specs.
PS. there are probably 3098758 topics on this if you search. Youll find reviews and thoughts there.</TD></TR></TABLE>
dude in no way is omni better than apex'i n1's 99 spec... why cus ive owned them, get them rebuilt
Old Aug 26, 2008 | 09:36 AM
itrjon's Avatar
Default Re: Coilover help (touchmyHONDA)
thanks guys, i'm leaning toward the PIC's
Old Aug 26, 2008 | 09:43 AM
Dave_B's Avatar
Another vote for PIC's here... I run them on both cars.
Also an AD for them if your looking to purchase a set.
Old Aug 26, 2008 | 09:46 AM
97CWITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itrjon &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys, i'm leaning toward the PIC's </TD></TR></TABLE>
Thinking the same thing.
I've driven in my buddies dc2 and he has the 12k/10k and its too much for me on the street. Leaning toward the 10k/8k setup.
I find it strange because I thought my old 12k/10k omni setup was alright for daily use....I guess not all spring rates are the same...?
Old Aug 26, 2008 | 05:57 PM
Tekkaboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">All depends on the cars purpose. If you road race/auto x then N1's, PIC is the way to go. If you just want to get low then just do a ground control/koni yellow build.</TD></TR></TABLE>
Technically, GC/koni yellows can be customized for road race/auto x.
You can get Ground Control (Eibach) springs in any spring rate you want.
Stock Koni Yellows work with springs up to 500 lbs/in (about 9k kg/mm) and if you want anything higher than that Koni can revalve them for you.
Old Aug 26, 2008 | 06:11 PM
pennies_hatchie's Avatar
Default Re: Coilover help (Tekkaboy)
I just upgraded from the PIC P3's to the R3's. So yeah, get PIC's.
Old Aug 26, 2008 | 06:48 PM
eluam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tekkaboy &raquo;</TD></TR><TR><TD CLASS="quote">
Stock Koni Yellows work with springs up to 500 lbs/in (about 9k kg/mm) and if you want anything higher than that Koni can revalve them for you.</TD></TR></TABLE>
You can go up to 600lbs on stock valved Konis.
Old Aug 27, 2008 | 09:55 AM
Tekkaboy's Avatar
Default Re: Coilover help (eluam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eluam &raquo;</TD></TR><TR><TD CLASS="quote">
You can go up to 600lbs on stock valved Konis.</TD></TR></TABLE>
Even better!
Old Aug 27, 2008 | 10:37 AM
get RIGHT's Avatar
Cant argue that.
Old Aug 27, 2008 | 03:46 PM
BMaDOHC's Avatar
Default Re: Coilover help (get RIGHT)
ive got PIC's and i like em. they were pretty cheap compared to everything else on the market. I have the 12/10 setup and it is a little much on the road, i would probably go with something a little softer
Old Aug 28, 2008 | 07:55 PM
Bbasso's Avatar
Default Re: Coilover help (97CWITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97CWITR &raquo;</TD></TR><TR><TD CLASS="quote">
the 12k/10k and its too much for me on the street. </TD></TR></TABLE>
Then get smoother streets
But 12/14 PIC for me everyday and Zero complaints.
Old Aug 29, 2008 | 12:07 PM
Hooch'n's Avatar
Default Re: (jgirard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgirard &raquo;</TD></TR><TR><TD CLASS="quote">I'm on JIC Magics, but I will be switching to PIC's The JIC's are fine but they aren't aggressive enough since they are 10k front 7k back</TD></TR></TABLE>
Old Aug 29, 2008 | 12:12 PM
jgirard's Avatar
Default Re: (Hooch'n)
What PIC's do you have Andy? R3's?
Old Aug 29, 2008 | 02:06 PM
Jpres927's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by touchmyHONDA &raquo;</TD></TR><TR><TD CLASS="quote">tein mono flex... Ive daily-ed this setup for over a year in Chicago weather and roads.... still amazing </TD></TR></TABLE>
i rode in this car almost once or twice a day all summer and have fallen in love with the mono flex's.
Old Aug 29, 2008 | 03:01 PM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgirard &raquo;</TD></TR><TR><TD CLASS="quote">What PIC's do you have Andy? R3's?</TD></TR></TABLE>
R3s are outstanding. I love mine and Andy, Walker, and Bbasso all agree.
Old Aug 29, 2008 | 03:52 PM
Ramrod918's Avatar
Default Re: (Erik95LS)
Im running KW suspension V2s, they handle great, not too stiff, very durable/resistant and they will last a lifetime w/warranty
Jdm-Vti
Suspension & Brakes
Jul 20, 2009 01:09 PM
The G2 Racer
Suspension & Brakes
12
Oct 30, 2008 07:31 AM
Lil Corb
Suspension & Brakes
Mar 1, 2006 04:55 AM
strict 9 ef
Jan 8, 2004 08:14 PM
civicracer6
Aug 7, 2001 11:48 PM
