Code 10
Old Mar 13, 2004 | 06:15 AM
EuN_TeK's Avatar
Default Code 10
I checked what code I was getting from my ECL and found it was code 10. I reset the ecu to get rid of it about 2 weeks ago and everything seemed fine. Until yesterday, it did it again... I check and its the same code. I changed my AEM CAI to stock intake, would that have set the ECL off? It didn't come on right away though, I've been running a week with the stock airbox. You guys think it will be ok if I reset the ECU once more? or should I have someone check it out? Any advice would be nice... Thanks~
Old Mar 13, 2004 | 07:41 AM
OUTKAST_R's Avatar
search for hondahybrid and they list the codes ?
Old Mar 13, 2004 | 08:23 AM
ZygSpeed's Avatar
Default Re: Code 10 (EuN_TeK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EuN_TeK &raquo;</TD></TR><TR><TD CLASS="quote">I checked what code I was getting from my ECL and found it was code 10. ... Thanks~</TD></TR></TABLE>
According to the codes listed in the ITR FAQ, a code "10" is for the Intake Air Temperature sensor. maybe the connection has become loose/disconnected or the sensor itself is having problems. HTH
Old Mar 13, 2004 | 09:44 AM
EuN_TeK's Avatar
Default Re: Code 10 (zygspeed)
Thank you for the info...
I think I may take it to an Acura Dealership...
I knew it was the Intake Air Temperature sensor but didn't know if it was the connection or sensor itself going bad...
If the sensor itself is going bad, does anyone know how much it costs to replace this?
drumminforev
25
Nov 11, 2006 09:19 PM
smokingemcee
Jun 22, 2006 05:21 AM
SOUTHCREX
Sep 24, 2002 04:35 PM
hybrider
Apr 3, 2002 02:25 AM
